ORCUTT
#1 Posted : Monday, December 8, 2014 11:53:22 AM(UTC)
ORCUTT
Help. Went into fridge this am. Fridge not cold, checked freezer, food half defrosted. Has power, light on. Evap. fan not running, cond. fan not running, comp. not running. Turned temp control off then all the way to 9. Not running. Unplugged unit, plugged back in, not running. Emptied unit. Pulled out, comp. cold to touch. Cond. fan spins by hand. Smacked compressor with hand, not running. Tilted unit back, checked cond. slightly dirty, cleaned. Put unit back on all fours. Not running. Scratching head, what to do next, comp. turns on by it's self. Check evap fan, running, Ck cond. fan running, unit getting cold.
Whats up?? Stuck defrost controller?? Bad temp controller?? or ???
THANK YOU FOR ANY HELP!!!!
#2 Posted : Monday, December 8, 2014 1:23:18 PM(UTC)
I do not know.
You did too many things.
When it happens again.
Turn the defrost timer cam.
There is usually a hole in the cover to let you do this.
The defrost timer should be in the control console.
If it fires up replace the defrost timer.
ORCUTT
#3 Posted : Monday, December 8, 2014 5:14:02 PM(UTC)
ORCUTT
Thank you, I'll try that. Just a note, I really didn't do anything. The only thing I really did is turn the temp control from 6 to off then to 9 and back to 6 and the fridge never turned on.
#4 Posted : Monday, December 8, 2014 5:36:31 PM(UTC)
By the sound of it you moved it around quite a bit and often if something is stuck a bit of a bang will unstick it.
U-Line Beverage/Wine Cooler has stopped cooling (Refrigerator & Freezer Repair)
by flossy21 12/13/2022 12:26:17 PM(UTC)
Fridgidare FFTR1814LWJ stopped cooling (Refrigerator & Freezer Repair)
by tizmylife 4/16/2021 6:54:21 PM(UTC)
Samsung RFG298 ...after 8 years...stopped cooling (Refrigerator & Freezer Repair)
by Vanhalo 3/21/2020 3:27:09 PM(UTC)
GE refrigerator stopped cooling and making a constant clicking sound (Refrigerator & Freezer Repair)
by Pacochu 8/12/2019 8:30:53 AM(UTC)
Fridge and freezer stopped cooling (Refrigerator & Freezer Repair)
by revg 8/12/2016 11:34:53 AM(UTC)
Mini fridge stopped cooling (Refrigerator & Freezer Repair)
by davidlandon 3/14/2016 7:07:24 AM(UTC)
GE bottom freezer fridge stopped cooling (Refrigerator & Freezer Repair)
by wdoolan 11/5/2014 2:20:31 PM(UTC)
whole side by side stopped cooling (Refrigerator & Freezer Repair)
by daleandtrish 6/9/2014 7:08:54 AM(UTC)
Haier Stopped Cooling (Refrigerator & Freezer Repair)
by sealuvr69 10/21/2013 8:15:05 AM(UTC)
Fridge stopped cooling completely (Refrigerator & Freezer Repair)
by Roper4321 9/1/2013 11:10:27 AM(UTC)
Amana Fridge stopped Cooling (Refrigerator & Freezer Repair)
by tklein1 8/19/2013 6:04:38 AM(UTC)
Freezer and Fridge stopped Cooling (Refrigerator & Freezer Repair)
by elanford 5/20/2013 2:04:25 PM(UTC)
GE Monogram stopped cooling. (Refrigerator & Freezer Repair)
by tgamble 5/8/2013 8:02:48 PM(UTC)
Fridge stopped cooling (Refrigerator & Freezer Repair)
by stevenjb 11/28/2012 2:54:10 PM(UTC)
Refrigerater and Freezer suddenly stopped cooling (Refrigerator & Freezer Repair)
by Thawood 10/23/2012 5:16:43 AM(UTC)
