Just bought a used Magic Chef refrigerator off craigslist.
The refrigerator seems to be cooling things adequately but the freezer is not working properly.
This may sound very weird, but it freezes water but not food.
When I got it home I put an ice cube tray in the freezer and a couple loafs of bread. The water in the cube trays froze, but 48 hours later the bread is still not frozen.
Has anyone ever heard of that?
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Measure the temperature in the freezer. It should be between 0 and 5 degrees F.
[COLOR="Blue"]Thanks denman! Im a noob. Worse, I don't have thermometer. [/COLOR] Originally Posted by: denman Also is the compressor on all the time except when the unit goes through a defrost cyc;le? [COLOR="Blue"]Sorry, I don't know. Can you advise how to check?[/COLOR]
[COLOR="Blue"]Worse, I don't have thermometer.[/COLOR] I would go and buy one for a couple bucks. You need to know the temperature. You know it is at or below 32 degrees F but how far below is important.
[COLOR="Blue"] Can you advise how to check?[/COLOR] You can usually hear it but also should be able to feel it vibrating. See section 1 in the parts.
Also check that the condenser/compressor fan is on when the compressor is on.
Check that the evaporator/freezer fan is running. |
Thanks for your reply denman. I have an update:
The temperature in the freezer is 18 degrees.
The fan in the freezer fan (evaporator fan) is working.
However, I can't figure out if the condenser/compressor fan is on when the compressor is on. If the evaporator fan is working and the freezer temp is 18 degrees does that mean the compressor is working?
Is there something that normally triggers the compressor fan so I can check that it's working?
[COLOR="Blue"]However, I can't figure out if the condenser/compressor fan is on when the compressor is on.[/COLOR] Not sure what the problem is. If you pull the unit away from the wall and remove the rear cover you can check the compressor, the compressor and and the cleanliness of the condenser coils.
[COLOR="Blue"]If the evaporator fan is working and the freezer temp is 18 degrees does that mean the compressor is working?[/COLOR] Yes but that is not the problem. The unit is not cooling efficiently. You have to find out why. I think you will find that the compressor is running constantly except when it goes into a defrost cycle which should last about half an hour.
If the unit is cycling normally then it could be a control thermostat problem.
[COLOR="Blue"]Is there something that normally triggers the compressor fan so I can check that it's working?[/COLOR] The Compressor fan, the compressor and the evaporator fan are likely wired in parallel so when one is on they all should be on. The parts link I included earlier does have a wiring diagram. |
Denman - I really appreciate you taking the time to help, but I'm simply not experienced in these things. Oh well, live and learn. We took the seller of this refrigerator at his word, but it seems clear that he snookered us. Thanks again.
