Discuss
ice build up-temp control
 in
Refrigerator & Freezer Repair
Hi just joined forum. Bought a house several months ago and the side-by-side frig in it. Told it works fine.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ice build up-temp control
  #1 (permalink)
Old 11-27-2014, 07:29 AM
Junior Member
odegrees is on a distinguished road
Default ice build up-temp control
Model Number: LFUS2613LPO   Brand: Frigidaire   Age: 1 - 5 years
Hi just joined forum. Bought a house several months ago and the side-by-side frig in it. Told it works fine. Soon after moving in, found ice block in what I think is the condensation pan area, got that out and made sure was draining fine. Starting to build again. Temp setting for freezer always says -20degreesF and frig 39degreesF digital. If I try to set freezer higher it will go to 6degreesF but later is back to -20degreesF. Water dispenser works sometimes. Makes ice fine. Any suggestions would be appreciated. Thank you.
Related Models
Frigidaire LFW201EW0 WASHER
 LFX21960ST Refrigerator
 LFX21971ST Refrigerator
 LFX21975ST Refrigerator
 LFX21980ST Refrigerator
 LFX23961SB Refrigerator
 LFX23961ST Refrigerator
 LFX23961SW Refrigerator
 LFX25950SB Refrigerator
 LFX25950SW Refrigerator
 LFX25950TT Refrigerator
 LFX25960SB Refrigerator
 LFX25960ST Refrigerator
 LFX25960SW Refrigerator
 LFX25960TT Refrigerator
 LFX25961SB Refrigerator
 LFX25961ST Refrigerator
 LFX25961SW Refrigerator
 LFX25971SB Refrigerator
 LFX25971ST Refrigerator
 LFX25971SW Refrigerator
 LFX25975SB Refrigerator
 LFX25975ST Refrigerator
 LFX25975SW Refrigerator
 LFX25980ST Refrigerator
Amana LG1009W DRYER- GAS
Amana LG1101 DRYER- GAS
Amana LG1112 WASHER-TOP LOADING
Amana LG1112 DRYER- GAS
Whirlpool LG2001XSW0 Residential Dryer
Amana LG2112L DRYER- GAS
Amana LG2112W DRYER- GAS
Amana LG2401 DRYER- GAS
Amana LG2412 WASHER-TOP LOADING
Amana LG2412 DRYER- GAS
Amana LG2501 DRYER- GAS
Amana LG2512 WASHER-TOP LOADING
Amana LG2512 DRYER- GAS
Amana LG2811 DRYER- GAS
Amana LG2812 WASHER-TOP LOADING
Amana LG2812 DRYER- GAS
Amana LG2902 WASHER-TOP LOADING
Amana LG2911 DRYER- GAS
Amana LG2912 WASHER-TOP LOADING
Amana LG2912 DRYER- GAS
Whirlpool LG3001XMW0 Residential Dryer
Whirlpool LG3001XMW1 Residential Dryer
Whirlpool LG3001XMW2 Residential Dryer
Whirlpool LG3001XPW0 Residential Dryer
Whirlpool LG3001XSW0 Residential Dryer
Whirlpool LG3006XPW0 Residential Dryer
Amana LG3412G DRYER- GAS
Amana LG3412L DRYER- GAS
Amana LG3412W DRYER- GAS
Amana LG3512L DRYER- GAS
Amana LG3512W DRYER- GAS
Amana LG3812L DRYER- GAS
Amana LG3812W DRYER- GAS
Amana LG3912L DRYER- GAS
Amana LG3912W DRYER- GAS
Frigidaire LG400AXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400AXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400SXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXD2 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXD3 Wwh(v1) / Laundry Center
Frigidaire LG400SXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXW2 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXW3 Wwh(v2) / Laundry Center
Amana LG4209L DRYER- GAS
Amana LG4209L2 DRYER- GAS
Amana LG4209W DRYER- GAS
Amana LG4209W2 DRYER- GAS
Amana LG4219L2 DRYER- GAS
Amana LG4219W2 DRYER- GAS
Amana LG4309L DRYER- GAS
Amana LG4309W DRYER- GAS
Amana LG4319L2 DRYER- GAS
Amana LG4319W2 DRYER- GAS
Amana LG4409L DRYER- GAS
Amana LG4409W DRYER- GAS
Amana LG4429L DRYER- GAS
Amana LG4429W DRYER- GAS
Whirlpool LG4441XWW0 Residential Dryer
Whirlpool LG4441XWW1 Residential Dryer
Amana LG4509L DRYER- GAS
Amana LG4509W DRYER- GAS
Amana LG4609L DRYER- GAS
Amana LG4609W DRYER- GAS
Amana LG4809L DRYER- GAS
Amana LG4809W DRYER- GAS
Amana LG4909L DRYER- GAS
Amana LG4909W DRYER- GAS
Whirlpool LG4931XMW0 Residential Dryer
Whirlpool LG4931XSW0 Residential Dryer
Whirlpool LG4931XTW0 Residential Dryer
Whirlpool LG4931XTW1 Residential Dryer
Whirlpool LG4931XTW2 Residential Dryer
Whirlpool LG4936XMW0 Residential Dryer
Whirlpool LG4936XMW1 Residential Dryer
Whirlpool LG5201XTW0 Residential Dryer
Whirlpool LG5201XTW1 Residential Dryer
Whirlpool LG5321XTW0 Residential Dryer
  #2 (permalink)
Old 11-28-2014, 05:41 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Frigidaire LFUS2613LP0 Refrigerator - AppliancePartsPros.com
Your problem with the icing up of the drain is probably related to the unit being too cold.
The most likely cause of this is a bad control board.
One thing to check is if this unit is on a designated/separate line.
If not you may want to try adding a surge protector to the line.
These are available at Home Depot etc.
A 1000 joule unit is preferred but a 750 protector should work if you cannot find a 1000.
They just plug into the wall receptacle and then you plug the fridge into it.
The reason is that [perhaps there are voltage spikes on the line and it is messing up your units computer.
This is a bit of a long shot but would be worth a try.
Even if it is not the problem you will still have additional protection for the unitr in the future.
__________________
  #3 (permalink)
Old 11-28-2014, 05:52 AM
Junior Member
Default
Thanks, I appreciate your help and information.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Temp Control MelKBY-6273 Oven Repair (including Ranges and Cooktops) 0 08-22-2012 07:32 AM
Temp control BobbyS Refrigerator & Freezer Repair 0 04-26-2012 06:32 PM
temp control way off fjr Refrigerator & Freezer Repair 0 06-26-2011 05:15 PM
temp control havasubear Refrigerator & Freezer Repair 0 10-05-2010 10:52 AM
Temp control not going down kevinwow Refrigerator & Freezer Repair 1 05-22-2009 04:45 PM
