| » Freezer and Fridge heating up |
Model Number: ksrg25fkwh03 Brand: Kitchen Aid Age: 1 - 5 years
I have a Kitchen aid Refridgerator and I'm having a problem with the temp. Both the freezer and the fridge are warming up.Now I'm pretty sure it's either the evap fan, defrost heater or the defrost timer but what I'm not sure about is how to test each one without replacing them all to find the problem...Any suggestions???
Related Models |
Replacement parts for WHIRLPOOL KSRG25FKWH03 | AppliancePartsPros.com Here is the tech sheet http://www.servicematters.com/docs/w...%202220109.pdf If the compressor and it's fan are working and the evaporator fan is not odds are high that it needs replacing. You only have a defrost problem if the evaporator coils are heavily iced/frosted up. Remove the coil cover and check them If they are heavily coated force a defrost cycle. See the tech sheet. If the heater heats up then replace the Electronic Defrost Control board. Be careful, do not burn your fingers. If it does not heat up it is probably the defrost heater itself or the defrost thermostat. Note may also still be the defrost timer board. Below are 2 good sites with additional info. http://www.applianceaid.com/frig.html Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com If it does not heat up
__________________
| Display Modes | |
| Amana Fridge:: Bottom freezer: Fridge freezing food | jobol | Refrigerator & Freezer Repair | 1 | 09-29-2009 04:02 PM |
| Fridge is blowing hot air in freezer and warm air in fridge | Kat Zurawski | Refrigerator & Freezer Repair | 1 | 08-18-2009 10:28 AM |
| Whirlpool fridge (bottom freezer style) top fridge shelf getting very cold | dieselgg | Refrigerator & Freezer Repair | 5 | 06-19-2009 05:51 AM |
| GE fridge, Freezer works, fridge dont.. need repair manual | kattkrzkatt | Refrigerator & Freezer Repair | 1 | 11-29-2008 10:45 AM |
| freezer.fridge not cold and leaking into fridge | fruitul | Refrigerator & Freezer Repair | 1 | 09-08-2008 04:20 PM |
