I Replaced Water Inlet Valve (wr57x10032) On Your Advise And It Did Not Correct The Problem. Can It Be The Switch Activator Since It In The Freezer Door? Everything Else Works Fine Ice Dispenser, Etc.
What Is Involved To Get Access To The Switch And Would You Recommend That I Can Do It?
I Am Returning The Water Inlet Valve, Do I Have To Pay The Return Charges, Since You Suggested It?
Thank You For Your Assistance!!
