Discuss
need fix a short in frig
 in
Refrigerator & Freezer Repair
I dont know how old it is. It trips a gfic socket. If I plug it into a regular grounded
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » need fix a short in frig
  #1 (permalink)
Old 11-04-2014, 04:57 AM
Junior Member
paulmars is on a distinguished road
Default need fix a short in frig
Model Number: MTB1753AR   Brand: Maytag   Age: More than 10 years
It trips a gfic socket. If I plug it into a regular grounded socket, it trips the 20a non gfic breaker. If I put a two way adapter on it to isolate the 3rd grounded wire, it runs fine. However PLEASE dont tell me that is dangerious. I know it is. I need to fix it. I dont see any obvious shorting on the power cable. I have a DVM and basic electrical knowledge.
maytag model MTB1753AR. It worksd fine for years, then one day after it was moved out to clean the floor, then moved back and then it started tripping the gfic and even a non gfic breaker as long as its grounded. Previously it worked fine in the gric or in a grounded regular socket.
ideas?
tks,
pa
Related Models
Maytag MTB1753ARA REF - TOP MOUNT
Maytag MTB1753ARW REF - TOP MOUNT
Maytag MTB1842VRW00 REFRIGERATOR
Maytag MTB1842VRW01 REFRIGERATOR
Maytag MTB1852VRW00 REFRIGERATOR
Maytag MTB1852VRW01 REFRIGERATOR
Maytag MTB1854VRB00 REFRIGERATOR
Maytag MTB1854VRB01 REFRIGERATOR
Maytag MTB1854VRS00 REFRIGERATOR
Maytag MTB1854VRS01 REFRIGERATOR
Maytag MTB1854VRW00 REFRIGERATOR
Maytag MTB1854VRW01 REFRIGERATOR
Maytag MTB1891ARQ REF - TOP MOUNT
Maytag MTB1891ARW REF - TOP MOUNT
Maytag MTB1893ARB REF - TOP MOUNT
Maytag MTB1893ARQ REF - TOP MOUNT
Maytag MTB1893ARS REF - TOP MOUNT
Maytag MTB1893ARW REF - TOP MOUNT
Maytag MTB1894ARB REF - TOP MOUNT
Maytag MTB1894ARS REF - TOP MOUNT
Maytag MTB1894ARW REF - TOP MOUNT
Maytag MTB1895AEB REF - TOP MOUNT
Maytag MTB1895AEQ REF - TOP MOUNT
Maytag MTB1895AES REF - TOP MOUNT
Maytag MTB1895AEW REF - TOP MOUNT
Maytag MTB1896AEB REF - TOP MOUNT
Maytag MTB1896AEQ REF - TOP MOUNT
Maytag MTB1896AES REF - TOP MOUNT
Maytag MTB1896AEW REF - TOP MOUNT
Maytag MTB189AARW REF - TOP MOUNT
Maytag MTB189BARW REF - TOP MOUNT
Maytag MTB1943ARA REF - TOP MOUNT
Maytag MTB1943ARQ REF - TOP MOUNT
Maytag MTB1943ARW REF - TOP MOUNT
Maytag MTB1946AEA REF - TOP MOUNT
Maytag MTB1946AEW REF - TOP MOUNT
Maytag MTB1946BEA REF - TOP MOUNT
Maytag MTB1946BEW REF - TOP MOUNT
Maytag MTB1948ARA REF - TOP MOUNT
Maytag MTB1948ARW REF - TOP MOUNT
Maytag MTB1948DRA REF - TOP MOUNT
Maytag MTB1948DRB REF - TOP MOUNT
Maytag MTB1948DRQ REF - TOP MOUNT
Maytag MTB1948DRW REF - TOP MOUNT
Maytag MTB1950FRQ REF - TOP MOUNT
Maytag MTB1950FRW REF - TOP MOUNT
Maytag MTB1950GRQ REF - TOP MOUNT
Maytag MTB1950GRW REF - TOP MOUNT
Maytag MTB1953ARA REF - TOP MOUNT
Maytag MTB1953ARW REF - TOP MOUNT
Maytag MTB1953HEQ REF - TOP MOUNT
Maytag MTB1953HEW REF - TOP MOUNT
Maytag MTB1954ARA REF - TOP MOUNT
Maytag MTB1954ARW REF - TOP MOUNT
Maytag MTB1954DRA REF - TOP MOUNT
Maytag MTB1954DRQ REF - TOP MOUNT
Maytag MTB1954DRW REF - TOP MOUNT
Maytag MTB1954EEB00 REFRIGERATOR
Maytag MTB1954EEB01 REFRIGERATOR
Maytag MTB1954EEB02 REFRIGERATOR
Maytag MTB1954EEB03 REFRIGERATOR
Maytag MTB1954EES00 REFRIGERATOR
Maytag MTB1954EES01 REFRIGERATOR
Maytag MTB1954EES02 REFRIGERATOR
Maytag MTB1954EES03 REFRIGERATOR
Maytag MTB1954EEW00 REFRIGERATOR
Maytag MTB1954EEW01 REFRIGERATOR
Maytag MTB1954EEW02 REFRIGERATOR
Maytag MTB1954EEW03 REFRIGERATOR
Maytag MTB1954MEB00 REFRIGERATOR
Maytag MTB1954MES00 REFRIGERATOR
Maytag MTB1954MEW00 REFRIGERATOR
Maytag MTB1955ARA REF - TOP MOUNT
Maytag MTB1955ARW REF - TOP MOUNT
Maytag MTB1955BRA REF - TOP MOUNT
Maytag MTB1955BRW REF - TOP MOUNT
Maytag MTB1955DRA REF - TOP MOUNT
Maytag MTB1955DRQ REF - TOP MOUNT
Maytag MTB1955DRW REF - TOP MOUNT
Maytag MTB1955ERQ REF - TOP MOUNT
Maytag MTB1955ERW REF - TOP MOUNT
Maytag MTB1955GRQ REF - TOP MOUNT
Maytag MTB1955GRW REF - TOP MOUNT
Maytag MTB1956AEA REF - TOP MOUNT
Maytag MTB1956AEB REF - TOP MOUNT
Maytag MTB1956AEW REF - TOP MOUNT
Maytag MTB1956BEA REF - TOP MOUNT
Maytag MTB1956BEB REF - TOP MOUNT
Maytag MTB1956BEW REF - TOP MOUNT
Maytag MTB1956DEA REF - TOP MOUNT
Maytag MTB1956DEB REF - TOP MOUNT
Maytag MTB1956DEQ REF - TOP MOUNT
Maytag MTB1956DEW REF - TOP MOUNT
Maytag MTB1956FEB REF - TOP MOUNT
Maytag MTB1956FEQ REF - TOP MOUNT
Maytag MTB1956FEW REF - TOP MOUNT
Maytag MTB1956GEB REF - TOP MOUNT
Maytag MTB1956GEQ REF - TOP MOUNT
Maytag MTB1956GEW REF - TOP MOUNT
Maytag MTB1972HRB REF - TOP MOUNT
Maytag MTB1972HRQ REF - TOP MOUNT
Maytag MTB1972HRW REF - TOP MOUNT
Maytag MTB1976HRB REF - TOP MOUNT
Maytag MTB1976HRQ REF - TOP MOUNT
Maytag MTB1976HRW REF - TOP MOUNT
Maytag MTB2146AEA REF - TOP MOUNT
Maytag MTB2146AEW REF - TOP MOUNT
Maytag MTB2146BEA REF - TOP MOUNT
Maytag MTB2146BEW REF - TOP MOUNT
Maytag MTB2148ARA REF - TOP MOUNT
Maytag MTB2148ARW REF - TOP MOUNT
Maytag MTB2148DRA REF - TOP MOUNT
Maytag MTB2148DRB REF - TOP MOUNT
Maytag MTB2148DRQ REF - TOP MOUNT
Maytag MTB2148DRW REF - TOP MOUNT
Maytag MTB2150FRQ REF - TOP MOUNT
Maytag MTB2150FRW REF - TOP MOUNT
Maytag MTB2150GRQ REF - TOP MOUNT
Maytag MTB2150GRW REF - TOP MOUNT
Maytag MTB2153ARA REF - TOP MOUNT
  #2 (permalink)
Old 11-04-2014, 05:48 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Most probably a compressor winding shorted to the frame.
__________________
  #3 (permalink)
Old 11-04-2014, 06:04 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Maytag MTB1753ARW Refrigerator - AppliancePartsPros.com
Yes it sounds like you have a live to unit frame short.
Can you tell what is turning on when it trips the breaker or is it as soon as you plug it in?
Turn the temperature control to off.
If it does not trip then the basic wiring and wiring to the lights (which should still work) is OK.
If the above checks out OK.
Unplug it and set the control to cool.
Take a look at the defrost timer.
There is usually a ho;le in the cover so this can be done without dismantling things.
Note where the timer cam is in it's rotation.
Then rotate the defrost timer cam.
In a 360 degrees rotation you can usually hear two clicks.
This is the turning on defrost and then turning off defrost.
They will be fairly close together as the rest of the rotation is the cooling mode.
Now see if the timer was in defrost or cooling mode.
Then move it to the other mode.
Then plug it in.
If you are now in defrost (fans and compressor stay off) and it does not blow then odds are that it is in the compressor or start device.
If you are now in cooling mode and it does not blow odds are that it is in the defrost circuit.
Most likely the defrost timer but could be the heater or defrost thermostat.
I hope i explained the above OK.
Basically you are trying to eliminate parts of the unit so that you do not have to disconnect a part at a time till you find the fault.
See the attachments for wiring your may not be an exact match but it is probably close.
__________________
  #4 (permalink)
Old 11-04-2014, 11:02 AM
Junior Member
Default
"Can you tell what is turning on when it trips the breaker or is it as soon as you plug it in?"
When it cycled off, I removed the grnd isolator and plugged it in and waited. Several minutes later I just barely heard the start of something and then the breaker tripped.
  #5 (permalink)
Old 11-04-2014, 11:22 AM
Junior Member
Default
"Turn the temperature control to off.
If it does not trip then the basic wiring and wiring to the lights (which should still work) is OK."
does not trip.
  #6 (permalink)
Old 11-04-2014, 11:27 AM
Junior Member
Default
"Take a look at the defrost timer.
There is usually a ho;le in the cover so this can be done without dismantling things."
I cant find a hole.
  #7 (permalink)
Old 11-04-2014, 11:35 AM
Junior Member
Default
pics
The message you have entered is too short. Please lengthen your message to at least 10 characters.
  #8 (permalink)
Old 11-04-2014, 11:47 AM
Junior Member
Default
6.6 and 2.7 ohms from hot and neutral (or neutral and hot) wires to frig metal case.
  #9 (permalink)
Old 11-05-2014, 11:30 AM
Senior Expert
APP Volunteer
Default
I am assuming that you are measuring to the start and run windings on the compressor.
Since they measure the same from Neutral and Hot (line) I would say you have a dead short from Neutral to Hot.
Measure from neutral to hot if it is 0 ohms then start disconnecting things till you find the short.
The compessor is the most likely as richappy said.
The following may also be helpful to you.
http://www.google.ca/url?sa=t&rct=j&...78677474,d.aWw
__________________
  #10 (permalink)
Old 11-05-2014, 08:58 PM
Junior Member
Default
I will check. If its zero ohms, then the frig would not work and the breaker would pop. Still i will check to see that it is.
I read almost 1/2 those posts at that link. I dont know what a 3 in one is. I could look it up, but Im not sure why.
p
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frig Runs Every Time The Frig Door Open johnnib99 Refrigerator & Freezer Repair 7 07-28-2012 04:40 PM
Good power to frig, but no light and frig dead, brand Haier robtskkh Refrigerator & Freezer Repair 3 05-17-2012 02:38 PM
GE Profile Frig, Temp freezing food in frig and water dispenser not working StamMKelly53 Refrigerator & Freezer Repair 10 02-05-2011 02:39 PM
Whirlpool Frig-Freezer good/Frig warm TD3 Refrigerator & Freezer Repair 5 12-18-2010 03:24 AM
GE frig freezer cold at bottom frig cool WRD0225 Refrigerator & Freezer Repair 0 08-16-2010 11:29 AM
