Discuss
GE compact died
 in
Refrigerator & Freezer Repair
Unit simply stopped working one day, and does not respond all. It is as if the GFI or circuit breaker
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE compact died
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-02-2014, 09:15 AM
Junior Member
John B. Parker is on a distinguished road
Default GE compact died
Model Number: SMR04DASACS   Brand: GE   Age: 1 - 5 years
Unit simply stopped working one day, and does not respond all. It is as if the GFI or circuit breaker tripped, but they did not.
Related Models
General Electric SMR04DASACS Refrigerator
General Electric SMR04DASBCS Refrigerator
General Electric SMR04DASCCS Refrigerator
General Electric SMR04GAUACS REFRIGERATOR
General Electric SMR04GAZACS REFRIGERATOR
Frigidaire SMS107T1B1 Tap(v0) / Microwave
Frigidaire SMS107T1B2 Tap(v0) / Microwave
Tappan SMS138T1(941354509) MICROWAVE OVEN
Frigidaire SMS138T1B Tap(v1) / 1.3 Microwave Oven
Tappan SMS138T1B(941354496) MICROWAVE OVEN
Frigidaire SMS138T1B2 Tap(v0) / 1.3 Microwave Oven
Tappan SMS138T1B2 (941354509) MICROWAVE OVEN
Frigidaire SMS139T1B Tap(v1) / 1.3 Microwave Oven
Tappan SMS139T1B(941354495) MICROWAVE OVEN
Frigidaire SMS139T1B2 Tap(v0) / 1.3 Microwave Oven
Tappan SMS139T1B2 (941354510) MICROWAVE OVEN 1.3
Bosch SMU2042 UC/09 (FD 7307-7504)
Bosch SMU2042 UC/09 (FD 7505-7902)
Bosch SMU2042 UC/13 (FD 7312-7504)
Bosch SMU2042 UC/13 (FD 7505-7902)
Bosch SMU2042 UC/14 (FD 7402-7504)
Bosch SMU2042 UC/14 (FD 7505-7902)
Bosch SMU2046 UC/09 (FD 7307-7902)
Bosch SMU2046 UC/13 (FD 7312-7902)
Bosch SMU2046 UC/14 (FD 7402-7902)
Bosch SMU3032 UC/14 (FD 7507-7902)
Bosch SMU3036 UC/14 (FD 7507-7902)
Bosch SMU4052 UC/09 (FD 7307-7902)
Bosch SMU4052 UC/14 (FD 7402-7902)
Bosch SMU4052 US/01 (FD 7106-7308)
Bosch SMU4052 US/08 (FD 7203-)
Bosch SMU4052 US/09 (FD 7210-)
Bosch SMU4056 UC/09 (FD 7307-7902)
Bosch SMU4056 UC/14 (FD 7402-7902)
Bosch SMU4056 US/01 (FD 7106-7308)
Bosch SMU4056 US/09 (FD 7211-)
Bosch SMU4092 UC/14 (FD -7902)
Bosch SMU4096 UC/14 (FD -7902)
Bosch SMU7052 UC/09 (FD 7307-7504)
Bosch SMU7052 UC/09 (FD 7505-7506)
Bosch SMU7052 UC/09 (FD 7507-7902)
Bosch SMU7052 UC/14 (FD 7402-7902)
Bosch SMU7052 UC/14 (FD 7507-7902)
Bosch SMU7052 US/02 (FD 7106-7308)
Bosch SMU7052 US/09 (FD 7210-)
Bosch SMU7056 UC/09 (FD 7307-7504)
Bosch SMU7056 UC/09 (FD 7505-7506)
Bosch SMU7056 UC/09 (FD 7507-7902)
Bosch SMU7056 UC/14 (FD 7402-7902)
Bosch SMU7056 UC/14 (FD 7507-7902)
Bosch SMU7056 US/02 (FD 7106-7308)
Bosch SMU7056 US/09 (FD 7210-)
 SMV9165BC MWAVE- MOUNTED OVER RANGE/WO
 SMV9165SC MWAVE- MOUNTED OVER RANGE/WO
Thermador SMW272B BUILT-IN OVEN
Thermador SMW272P BUILT-IN OVEN
Thermador SMW272S BUILT-IN OVEN
Thermador SMW272W BUILT-IN OVEN
Thermador SMW272YB AFTER S/N 8204
Thermador SMW272YS AFTER S/N 8204
Thermador SMW272YW AFTER S/N 8204
Thermador SMW272ZS AFTER S/N 8204
Thermador SMWS72YP AFTER S/N 8204
Bosch SMZ3022
Bosch SMZ3044
Bosch SMZ3055
Bosch SMZ3077
Bosch SMZ3088
Amana SNAC-700.A COMMERCIAL MICROWAVES
Amana SNAC-700.B COMMERCIAL MICROWAVES
Amana SNAC-7TP.A COMMERCIAL MICROWAVES
Amana SNAC-7TP.B COMMERCIAL MICROWAVES
Amana SNAC700 COMMERCIAL MICROWAVES
Amana SNAC700.C COMMERCIAL MICROWAVES
Amana SNAC700.D COMMERCIAL MICROWAVES
Amana SNAC7TP.003 COMMERCIAL MICROWAVES
Amana SNAC7TP.004 COMMERCIAL MICROWAVES
Amana SNAC7TP.005 COMMERCIAL MICROWAVES
Amana SNAC8LW COMMERCIAL MICROWAVES
Amana SNE26AA RANGE - ELECTRIC STD DELAWARE
Amana SNE26CB RANGE- S/C S/I DDRAFT GAS
Amana SNE26CB RANGE - ELECTRIC STD DELAWARE
Amana SNE26ZZ RANGE- S/C S/I DDRAFT GAS
Amana SNK26AA RANGE- S/C S/I DDRAFT GAS
Amana SNK26AA0 RANGE- S/I STD GAS
Amana SNK26AA5 RANGE- S/I STD GAS
Amana SNK26CB RANGE- S/C S/I DDRAFT GAS
Amana SNK26CB0 RANGE- S/I STD GAS
Amana SNK26CB5 RANGE- S/I STD GAS
Amana SNK26FS RANGE- S/C S/I DDRAFT GAS
Amana SNK26FS0 RANGE- S/I STD GAS
Amana SNK26FS5 RANGE- S/I STD GAS
Amana SNP26AA RANGE- S/I STD GAS
Amana SNP26AA0 RANGE- S/I STD GAS
Amana SNP26AA5 RANGE- S/I STD GAS
Amana SNP26AH0 RANGE- S/I STD GAS
  #2 (permalink)
Old 10-03-2014, 01:19 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for GE SMR04DASACS Refrigerator - AppliancePartsPros.com
Have you checked the power at the wall receptacle?
If not I would do that.
Next check for the 120 volts at the machine end on the power cord.
If OK
Unplug the unit and the two wires at the control thermostat.
Check across the thermostat with a meter, should be 0 ohms.
OR
Short the two wires together.
You may have to tape them so they do not short to anything else.
Now plug the unit in to see what happens.
If it starts up you need a new control thermostat.
__________________
  #3 (permalink)
Old 10-03-2014, 09:12 AM
Junior Member
Default
Quote:
Originally Posted by denman View Post
If OK
OR
Thank you so much. I shorted the control switch wires, as suggested, and it worked. Is this a part from you, or or is it easily sourced at the local GE or hardware store?
The power to the original switch (white wire) is hard wired. Is this a job for a simple connector?
  #4 (permalink)
Old 10-03-2014, 11:41 AM
Senior Expert
APP Volunteer
Default
I cannot say.
Would be best to talk to a parts representative, they have more info and expertise than I have.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fuse for compact refrigerator? beckymon Refrigerator & Freezer Repair 0 05-06-2012 09:26 AM
compact washer jimlorton Washer Repair 0 02-20-2010 01:02 PM
Ram does not compact lgreganti Trash Compactor Repair 0 01-18-2010 07:01 AM
compact refrigerator Jolds Refrigerator & Freezer Repair 0 08-21-2009 07:43 AM
compactor will not compact JFOSTER Trash Compactor Repair 1 05-09-2009 02:13 PM
