The water line leading to the water filter has a leak about 6 inches from where it goes into the fridge. This is the second leak in the line (other was about 8 inches down the line). Can this 5/16 line be replaced since its becoming brittle and if so, how do you get it out since it seems to go through a sealed opening in the back of the fridge? Thanks.
