Unit used to make a significant sucking sound when door was closed, indicating a vacuum & the door was impossible to open until suction stopped. Door was then secure. Now there is little or no sound when door is closed & I've found the unit running with the door slightly open several times. I'm assuming the vacuum assures that the door closes snuggly allowing the magnets to keep the door closed. Suggestions please.
