Thanks in advance for your help in resolving this issue. I have a GE Profile (PSS26SGRD SS). Been having issues with slow water dispenser.
1) Changed the filter a couple of times with no avail. 2) Tested the water pressure on the back of the refrigerator and it's quite sufficient (water actually shot up to the other end of the kitchen!) 3) Checked for kinks on the back and ensured there aren't any. 4) Using the bypass plug or filter makes no difference. The dispenser dispenses a very thin thread of water.
Here's the funny thing. Till the last filter replacement, when I removed the filter, other than a few drops of water, there was no leakage from where the filter used to be. Over the last two days, the water dispenser became really slow. When I removed the bypass filter, the water is not stopping! Shouldn't it stop water when the filter/plug removed? What could be wrong? How can I increase the flow + fix the leak?
