estate 14cf fridge....leaks water during defrost cycle drip pan is metal, so its not cracked drain line not plugged up....poured 3 glasses of water through it....went to drain pan....didn't overflow....didn't leak no water in bottom of unit under vegetable bins....not leaking thru cold air vents
any other suggestions?....thanx in advance
