Refg is a side by side with ice maker and water dispenser on freezer side. No lights are visible on control panel on freezer door. Will not dispense ice or water. Ice maker still makes ice and refg inside lights all work and unit cools fine.
Purchased a control board Part # W101-45184 Rev A ( same part # on old board ) Installed but Refg will not come on. No lights no power. I can put the old board back in and get power but with the same old problems. Had parts company replace the new board but still get the same results with the second new board.
Need assistance and advice.
Thanks,
Larry
