Discuss
Refrigerator
 in
Refrigerator & Freezer Repair
Compressor is not running, & the start device smells burned and has tiny pieces falling out of it. The condensor
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-17-2008, 11:30 AM
leith leith is offline
Junior Member
leith is on a distinguished road
Default Refrigerator
Model Number: GD5SHAXLQ02   Brand: Whirlpool   Age: 1 - 5 years
Compressor is not running, & the start device smells burned and has tiny pieces falling out of it. The condensor was also dirty. Is there anyway I can check the compressor myself to see if it's locked up, or if it's just caused by the start device not working? Any suggestions will be helpful. thanks, Leith
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-18-2008, 11:49 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Leith,
The compressor consists of two major parts: electrical motor and mechanical pump. We can test only the motor windings.
Remove the start device from the compressor and measure resistance across all pairs of the terminals and across each terminal and the ground.
Normally it's supposed to be between 3 Ohms to 10 Ohms reading across terminals and ∞ reading across any of the terminals and the ground.
If there is nothing wrong you must replace the start device to check the condition of the mechanical part of the compressor.
Problems with the start devices are much more common than a faulty mechanical parts in such compressors.
- The part number for the start devise is AP3885081
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
