AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Ge monogram stainless steel counter depth freezer hot fridge too cold
The fridge gets close to freezing and keeps running. The freezer gets warmer 15 degrees or so. I believe it is related to a bad freezer evaporator thermistor blue wire j1 pin 3. I have replaced four thermistors even in the warming drawer. The only info I have is the original main board EBX1005G01 is probably compatible with WR55X10942. I need wiring diagram / schematic and pin outs for this board. The temperature control is digital. The warming / cooling temperature control drawer does not work and I need a board for that as well. Oreocookie attached the following image(s):
