Condenser fan is not turning. I have used the test procedure below and measured DC volts at J2 using the instructions below. I am measuring NEGATIVE 13 volts at both pin 3 and pin 8 test and pin 3 and pin 5 test. Can someone tell me if this is okay? GE Refrigerator Fan Motor Diagnostics ( GE Refrigerator Fan Motor Diagnostics) Thanks for your help.
