Discuss
performing tests
 in
Refrigerator & Freezer Repair
I got a bit of info by hi-jacking another thread. It got me heading for the t-stat control as it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » performing tests
  #1 (permalink)
Old 10-24-2009, 03:10 PM
Junior Member
bullyandbif is on a distinguished road
Default performing tests
Model Number: ed25twxdw01   Brand: Whirlpool   Age: More than 10 years
I got a bit of info by hi-jacking another thread. It got me heading for the t-stat control as it had burnt contacts so I orderd another. The fridge was running till cold but then would not kick on again unless I turned the control on/off to cycle it.
I started this thread because I got the control to allow contact again by a bit of tlc. (it still will be replaced, I just wanted to get it going to test the other parts) I read the sticky but still am asking for confermation on my findings.
The heater has continuity -means good yes?
The bi-metal t-stat has continuity while froze,none when warmed up. I can actualy here it snap when it switches. - good?
Fans are running.
coils are clean.
I have not tried the defrost timer as not sure turning the screw(thing) would render it useless...can this be tested and reset?
Just want to make sure I only need the control t-stat and not more parts.
Thanks again.
bullyandbif
Ads By Google
Related Models
Whirlpool ED25TWXDW01
Whirlpool ED25UEXHT00
Whirlpool ED25UEXHT01
Whirlpool ED25UEXHW00
Whirlpool ED25UEXHW01
Whirlpool ED25UQXGN00
Whirlpool ED25UQXGN01
Whirlpool ED25UQXGW00
Whirlpool ED25UQXGW01
Whirlpool ED25VFXHT00
Whirlpool ED25VFXHT01
Whirlpool ED25VFXHT02
Whirlpool ED25VFXHW00
Whirlpool ED25VFXHW01
Whirlpool ED25VFXHW02
Whirlpool ED25YQXAN00
Whirlpool ED25YQXAW00
Whirlpool ED26MK1LWR0
Whirlpool ED26MK1LWR1
Whirlpool ED26MKXLWR0
Whirlpool ED26MKXRWR0
Whirlpool ED26MM1LWR0
Whirlpool ED26MM1LWR1
Whirlpool ED26MMXLWR0
Whirlpool ED26MMXRWR0
Whirlpool ED26MMXRWR2
Whirlpool ED26MMXRWR3
Whirlpool ED26MMXRWR4
Whirlpool ED26SSXLWR0
Whirlpool ED26SSXLWR1
Whirlpool ED26SSXMWR1
Whirlpool ED26SSXRWR0
Whirlpool ED27DQXAB03
Whirlpool ED27DQXAB04
Whirlpool ED27DQXAB05
Whirlpool ED27DQXAN02
Whirlpool ED27DQXAN03
Whirlpool ED27DQXAN04
Whirlpool ED27DQXAN05
Whirlpool ED27DQXAW02
Whirlpool ED27DQXAW03
Whirlpool ED27DQXAW04
Whirlpool ED27DQXAW05
Whirlpool ED27DQXBB00
Whirlpool ED27DQXBB01
Whirlpool ED27DQXBB02
Whirlpool ED27DQXBN00
Whirlpool ED27DQXBN01
Whirlpool ED27DQXBN02
Whirlpool ED27DQXBW00
Whirlpool ED27DQXBW01
Whirlpool ED27DQXBW02
Whirlpool ED27DQXDB00
Whirlpool ED27DQXDB01
Whirlpool ED27DQXDB02
Whirlpool ED27DQXDB03
Whirlpool ED27DQXDB04
Whirlpool ED27DQXDN00
Whirlpool ED27DQXDN01
Whirlpool ED27DQXDN02
Whirlpool ED27DQXDN03
Whirlpool ED27DQXDN04
Whirlpool ED27DQXDW00
Whirlpool ED27DQXDW01
Whirlpool ED27DQXDW02
Whirlpool ED27DQXDW03
Whirlpool ED27DQXDW04
Whirlpool ED27DQXWN00
Whirlpool ED27DQXWN01
Whirlpool ED27DQXWN10
Whirlpool ED27DQXWN11
Whirlpool ED27DQXWN12
Whirlpool ED27DQXWW00
Whirlpool ED27DQXWW01
Whirlpool ED27DQXWW10
Whirlpool ED27DQXWW11
Whirlpool ED27DQXWW12
Whirlpool ED27DQXXN00
Whirlpool ED27DQXXN01
Whirlpool ED27DQXXN02
Whirlpool ED27DQXXW00
Whirlpool ED27DSXDB00
Whirlpool ED27DSXDB01
Whirlpool ED27DSXDB03
Whirlpool ED27DSXDB05
Whirlpool ED27DSXDB06
Whirlpool ED27DSXDN00
Whirlpool ED27DSXDN01
Whirlpool ED27DSXDN03
Whirlpool ED27DSXDN05
Whirlpool ED27DSXDN06
Whirlpool ED27DSXDW00
Whirlpool ED27DSXDW01
Whirlpool ED27DSXDW03
Whirlpool ED27DSXDW05
Whirlpool ED27DSXDW06
Whirlpool ED27PEXHB00
Whirlpool ED27PEXHB01
Whirlpool ED27PEXHB02
Whirlpool ED27PEXHT00
Whirlpool ED27PEXHT01
Whirlpool ED27PEXHT02
Whirlpool ED27PEXHW00
Whirlpool ED27PEXHW01
Whirlpool ED27PEXHW02
Whirlpool ED27PQXEN00
Whirlpool ED27PQXEN01
Whirlpool ED27PQXEW00
Whirlpool ED27PQXEW01
Whirlpool ED27PQXFN00
Whirlpool ED27PQXFN01
Whirlpool ED27PQXFN02
Whirlpool ED27PQXFW00
Whirlpool ED27PQXFW01
Whirlpool ED27PQXFW02
Whirlpool ED27QFXHB00
Whirlpool ED27QFXHB01
Whirlpool ED27QFXHB02
Whirlpool ED27QFXHT00
Whirlpool ED27QFXHT01
  #2 (permalink)
Old 10-24-2009, 04:37 PM
Senior Expert
APP Volunteer
denman is just really nice
Default
Yes
Yes
Fans are running.
This is good
coils are clean.
This also is good
Yes you can turn the timer cam. Most of them have a ramp with a flat side so that a screwdriver will only grab if turned in the correct direction. Trying to force it in the wrong direction will screw it up.
There is no need to reset it. It should finish the defrost cycle and restart the fridge compressor and fans.
If it does this and the heater heats up odds are good that it is OK
__________________
  #3 (permalink)
Old 10-24-2009, 04:54 PM
Junior Member
Default
Denman, thanks for the help.
bullyandbif
  #4 (permalink)
Old 10-25-2009, 01:42 AM
Senior Expert
APP Volunteer
Default
You are welcome.
I am pretty sure that the defrost will check out OK for you as usually it will not defrost at all once something fails and the only way to get the unit up and running again is to do a manual defrost.
__________________
  #5 (permalink)
Old 10-27-2009, 01:39 PM
Junior Member
Default
OK , got my new t-stat control today.
Its all up and runnin again.
Before i go crazy and put food back in it. What are the "normal" temp
settings for freezr and refridge sides? I'm checking w/ a thermometer to
make sure its working in the right temp range.
Reason I'm asking is the t-stat has an adjustment screw--these preset?
I'm sure I will just have to adjust the knobs over time to get the temps to my liking again...frozen cheese,fury sour cream, and the icecream so hard it could be a jack stand for my pickup truck.
Thanks again all, saved aloto cash fixin it myself
bullyandbif
  #6 (permalink)
Old 10-27-2009, 04:20 PM
Senior Expert
APP Volunteer
Default
Yes it is preset/calibrated at the factory so you should not touch it.
Refrigerator Temps
Freezer: 0 to 5 degrees (F)
Fresh Food: about 38 degrees (F)
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more.
To test the freezer, substitute alcohol or cooking oil.
__________________
  #7 (permalink)
Old 10-27-2009, 04:37 PM
Junior Member
Default
10-4 on the temps.
Again, thanks alot for the support.
Gonna tackle my FIL malfunctioning oven next.
bullyandbif
Over.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ohms & amp tests mysterhandyman Dryer Repair 0 10-04-2009 01:56 PM
Tech Sheet Tests Freddiegeez Washer Repair 1 06-25-2009 01:18 PM
Maytag Performa not performing lineberryt Dryer Repair 0 02-13-2009 09:14 AM
