derfrewol
#1 Posted : Monday, August 4, 2014 11:58:03 AM(UTC)
derfrewol
Freezer is at the proper temp.(0 Degrees) . Fridge is too cold.(32-33 degrees) Fridge temp is set to be 40 degrees. Please help.
#2 Posted : Tuesday, August 5, 2014 2:15:57 AM(UTC)
adjust the fridg temperature controls up and down. Can you hear the damper door open, then close. If not, you might have a stuck open damper door.
derfrewol
#3 Posted : Tuesday, August 12, 2014 6:10:04 AM(UTC)
derfrewol
Sorry for the delay getting back to you, I have been out of traveling and have not been able to check the damper until today. It was indeed stuck open. When wiggled the connector it closed. I took the connector apart and cleaned the contacts and am testing it now. Thank you for the help.
derfrewol
#4 Posted : Monday, August 18, 2014 2:05:47 AM(UTC)
derfrewol
Ordered new damper control assembly. It came over night. Installed it and cured the problem. Thank you for the help.
