Water is consistently pooling at the bottom of the refrigerator section. It appears to be running down from the center back of the fridge - I verified this by placing a sponge below the LED light which caught the water before it pooled on the bottom. Water will eventually fill up the bottom of the fridge and leak out the front... which takes several days to several weeks (not consistent). It also will freeze causing the deli drawer to stick. I attached some pictures to better explain the issue and what I have attempted to do so far... not sure if I was on the right track. Any help will be greatly appreciated! skyshow1 attached the following image(s):
