Discuss
Voltage to defrost heater hotpoint fridge
 in
Refrigerator & Freezer Repair
I went to look at a fridge which is a basic apartment GE Hotpoint. CLeaned coils and made sure both
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Voltage to defrost heater hotpoint fridge
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 07-28-2014, 06:30 PM
Junior Member
daddyduz is on a distinguished road
Default Voltage to defrost heater hotpoint fridge
Brand: GE   Age: 1 - 5 years
I went to look at a fridge which is a basic apartment GE Hotpoint. CLeaned coils and made sure both fans clean and clear. Compressor running properly but found that coils in freezer was froze. Defrost timer working properly, I also checked resistance across defrost heater and was also good. I did not check resistance at defrost thermostat, but I did replace it just because I had one. Im still not getting defrost heater still working. I tested voltage with power on, which is where I am un clear of.. what voltage should be. With power on just a ghost reading, turn timer to off Im running 24v - 30v... Is this the correct voltage, somehow im pretty sure thats not right and what should be, also if not what am I missing to get this fridge correct... The defrost heater not getting hot seems the only problem with fridge though... Thanks Justin.. Kansas
  #2 (permalink)
Old 07-28-2014, 09:46 PM
Junior Member
bfridge is on a distinguished road
Default
Normally the voltage across the defrost heater should be 120VAC. Since you are getting lower than that, it suggest that the problem is within the control board or the wire harness between the control board and the heater.
However, make sure to test the voltage when the heater is at freezing temperature not room temperature.
  #3 (permalink)
Old 07-29-2014, 04:55 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Sorry but I do not understand the above.
Again I find the above confusing.
I am not sure what you mean by power off and power on.
The defrost timer is always on if the unit is plugged in.
I assume that by power on you mean the timer is in the cooling mode/position.
I also assume that by power off you mean that the timer is in the defrost position re: the compressor and fans shut off and the defrost heater should turn on as long as the defrost thermostat is frozen.
As bfridge said you should see 120 volts across the heater, defrost thermostat combo (they are wired in series).
If not and the wiring from the defrost heater to the defrost time is OK then the defrost thermostat is bad re: the contacts are not closing when in defrost.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer defrost heater voltage ttomasko Refrigerator & Freezer Repair 7 08-25-2017 10:05 PM
GE SxS partial voltage across defrost heater joshhighley Refrigerator & Freezer Repair 2 11-04-2013 02:27 PM
no voltage to defrost heater during defrost cycle george63 Refrigerator & Freezer Repair 0 08-23-2012 04:38 PM
no voltage to refreg defrost heater george63 Refrigerator & Freezer Repair 0 08-23-2012 01:39 PM
Defrost heater voltage PoRider Refrigerator & Freezer Repair 0 07-12-2010 09:40 PM
