Discuss
Amana refrig/freezer door gasket replace
 in
Refrigerator & Freezer Repair
Hi Folks, Are there any instructions/hints/how-to's about replacing the refrigerator and freezer door gaskets on the listed frig? (Amana ARB2205CW
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana refrig/freezer door gasket replace
  #1 (permalink)
Old 10-24-2009, 10:59 AM
Junior Member
Lulalake is on a distinguished road
Default Amana refrig/freezer door gasket replace
Model Number: ARB2205CW   Brand: Amana   Age: 5 - 10 years
Hi Folks,
(Amana ARB2205CW bottom freezer model)
Thanks very much
LL
Ads By Google
Related Models
Amana ARB2205CW  Ref - Bottom Mounts
Amana ARB220RCB  Ref - Bottom Mounts
Amana ARB220RCC  Ref - Bottom Mounts
Amana ARB220RCW  Ref - Bottom Mounts
Amana ARB220ZCB  Ref - Bottom Mounts
Amana ARB220ZCC  Ref - Bottom Mounts
Amana ARB220ZCS  Ref - Bottom Mounts
Amana ARB220ZCW  Ref - Bottom Mounts
Amana ARB2214CB  Ref - Bottom Mounts
Amana ARB2214CC  Ref - Bottom Mounts
Amana ARB2214CSL  Ref - Bottom Mounts
Amana ARB2214CSR  Ref - Bottom Mounts
Amana ARB2214CW  Ref - Bottom Mounts
Amana ARB2217CB  Ref - Bottom Mounts
Amana ARB2217CC  Ref - Bottom Mounts
Amana ARB2217CSL  Ref - Bottom Mounts
Amana ARB2217CSR Ref - Bottom Mounts
Amana ARB2217CW  Ref - Bottom Mounts
Amana ARB224RCB  Ref - Bottom Mounts
Amana ARB224RCC  Ref - Bottom Mounts
Amana ARB224RCW  Ref - Bottom Mounts
Amana ARB2257CB  Ref - Bottom Mounts
Amana ARB2257CC  Ref - Bottom Mounts
Amana ARB2257CSL  Ref - Bottom Mounts
Amana ARB2257CSR  Ref - Bottom Mounts
Amana ARB2257CW  Ref - Bottom Mounts
Amana ARB2259CB  Ref - Bottom Mounts
Amana ARB2259CC  Ref - Bottom Mounts
Amana ARB2259CS  Ref - Bottom Mounts
Amana ARB2259CW  Ref - Bottom Mounts
Amana ARB2517CB  Ref - Bottom Mounts
Amana ARB2517CC  Ref - Bottom Mounts
Amana ARB2517CSL  Ref - Bottom Mounts
Amana ARB2517CSR  Ref - Bottom Mounts
Amana ARB2517CW  Ref - Bottom Mounts
Amana ARB2557CB  Ref - Bottom Mounts
Amana ARB2557CC  Ref - Bottom Mounts
Amana ARB2557CSL  Ref - Bottom Mounts
Amana ARB2557CSR  Ref - Bottom Mounts
Amana ARB2557CW  Ref - Bottom Mounts
Amana ARB8057CB  Ref - Bottom Mounts
Amana ARB8057CC  Ref - Bottom Mounts
Amana ARB8057CSL  Ref - Bottom Mounts
Amana ARB8057CSR  Ref - Bottom Mounts
Amana ARB8057CW  Ref - Bottom Mounts
Amana ARB9058CB  Ref - Bottom Mounts
Amana ARB9058CS  Ref - Bottom Mounts
Amana ARB9058CW  Ref - Bottom Mounts
Amana ARB9059CS  Ref - Bottom Mounts
Amana ARC-1 Range - S/c S/i Ddraft Gas
Amana ARC-100 Range - S/c S/i Ddraft Gas
Amana ARC-100B Range - S/c S/i Ddraft Gas
Amana ARC-1B Range - S/c S/i Ddraft Gas
Amana ARC-2 Range - S/c S/i Ddraft Gas
Amana ARC-2B Range - S/c S/i Ddraft Gas
Amana ARC-506 Range - S/c S/i Ddraft Ele
Amana ARC100B Range - S/c S/i Ddraft Ele
Amana ARC100D Range - S/c S/i Ddraft Ele
Amana ARC1B Range - S/c S/i Ddraft Ele
Amana ARC502W Range - S/c S/i Ddraft Ele
Amana ARC505 Range - S/c F/s Ele
Amana ARC505B Range - S/c S/i Ddraft Ele
Amana ARC515 Range - S/c S/i Ddraft Ele
Amana ARC700E Range - S/c S/i Ddraft Ele
Amana ARC700LL Range - S/c S/i Ddraft Ele
Amana ARC700WW Range - S/c S/i Ddraft Ele
Amana ARDS800E Range - S/c S/i Ddraft Ele
Amana ARDS800WW Range - S/c S/i Ddraft Ele
Amana ARDS801E Range - S/c S/i Ddraft Ele
Amana ARDS801WW Range - S/c S/i Ddraft Ele
Amana ARDS802E Range - S/c S/i Ddraft Ele
Amana ARDS802SS Range - S/c S/i Ddraft Ele
Amana ARDS802WW Range - S/c S/i Ddraft Ele
Amana ARE14 Misc / Accessory
Amana ARE640 Range - S/c S/i Ddraft Gas
Amana ARE650 Range - S/c S/i Ddraft Gas
Amana ARG3600L Range - S/i Std Gas
Amana ARG3600LL Range - S/c S/i Ddraft Gas
Amana ARG3600W Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 10-31-2009, 11:34 AM
Junior Member
Default
Figured it out.
How simple!!!!
The Gasket simply pulls put and the replacement is simply pushed in. A 5 minute job . . HOWEVER . . .
The gasket is somewhat subject to twisting (and staying twisted) so the Amana people include how-to-untwist instructions in the gasket box.
You simply heat the gasket with a hair dryer or a bright light and it comes pretty close back to shape.
Mine was twisted and I followed the instruction.
It worked.
I am now a hero in my wifes eyes .. .Shhh don't tell her it was that easy.
Cheers
Jules
  #3 (permalink)
Old 11-19-2009, 05:12 PM
Junior Member
paintingchic is on a distinguished road
Default
so a girl can do it???!
  #4 (permalink)
Old 11-21-2009, 06:47 AM
Junior Member
Default
Yep, if she has at least one eye, and one arm and hand, 50 something bucks depending on the gasket vendor (shop around as the prices vary) and 5 minutes ;-)
(Shhhh, don't tell him it's that easy)
  #5 (permalink)
Old 07-31-2010, 09:38 AM
Junior Member
sudsjain is on a distinguished road
Default Took me 2 hours to replace
Last night, I replaced the gasket of the bottom freezer drawer on my Amana refrigerator. It was actually harder than the explanations on this forum. It took me about 2 hours.
When I took my new gasket out of the package that it was mailed in, it had been folded and was all twisted. There were wrinkles in the area where the actual magnetic seal occurs. I tried to use a hair dryer to smooth out the wrinkles but the hair dryer just wasn't getting hot enough. I decided to install the gasket anyway hoping that the wrinkles would just get stretched out.
First I had to remove the drawer which is explained in the Amana manual. I had to remove two screws on the side the the drawer slides and then lift out the hanger for the door. Pulling out the old gasket was really easy but when I tried to push the new gasket it just wouldn't go in under the lip and I was afraid that it would get torn if I pushed it in with a screwdriver.
So I had to remove all 20 or so screws that hold the white plastic retaining liner in and hold the lip of the gasket. Then I had to slide a flat head screw driver in to lift up the liner and break the gluing effect of the expanding foam insulation used during manufacturing. Once I could freely lift up the liner about 1/4 inch, I was able to push the new liner in. The wrinkles were still there, which would have prevented a good seal. Fortunately I had a heat gun which I tested first on the old gasket. This worked wonderfully after the gasket was fully installed and did not melt the white plastic liner.
Once the gasket was installed and all 20 screws were tightened, I discovered that the door had been twisted a little and the left side of the drawer would hit first leaving a gap on the right side. By pushing on the right side some time it would stay but often it wouldn't. So I loosened the screws that hold the door on to the metal hangers that attached to the glides and then twisted the door while I tightened those screws.
The final fix was to tighten the leveling screws so that the top of the fridge leans back. This is recommended in Amana's instructions but had not been done for our fridge. This causes gravity to pull the drawer closed.
I don't mean to scare anyone away from doing this repair but it ended up being harder than I thought.
  #6 (permalink)
Old 07-31-2010, 11:57 AM
Junior Member
Default
Thanks for your detailed story. As you know this stuff can and does happen.
Good for you
Jules
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Looking for Freezer Door Gasket for my Amana Refrigerator Darrellhis Refrigerator & Freezer Repair 0 08-11-2009 05:00 PM
replacing bottom freezer door gasket how is gasket held in place on this model MrNigel Refrigerator & Freezer Repair 0 07-21-2009 05:10 PM
replace door & freezer gasket momeyd Refrigerator & Freezer Repair 2 06-20-2009 05:45 AM
Amana Refrig. Door Gasket mrhogan Refrigerator & Freezer Repair 0 05-22-2009 11:14 AM
replace freezer door gasket talexander Refrigerator & Freezer Repair 0 09-04-2008 10:03 AM
