RGP
#1 Posted : Friday, July 25, 2014 5:35:28 AM(UTC)
RGP
My ice maker is not working. I replace the unit 6 months ago and everything was fine. Then I started making hollow ice cubes which jammed in the unit. Then it stop working. I think the motor burned out. I replaced the unit and the water valve valve which was leaking. Now I get nothing. Is their a fuse or reset someway I should check. Water is flowing to the valve.
HELP
bfridge
#2 Posted : Friday, July 25, 2014 10:46:23 AM(UTC)
bfridge
It sounds like your original problem was either the water fill time was too low or that the thermistor inside the ice maker was not working properly. It is possible that the motor in the ice maker was faulty and when it was jammed it caused it to burn out.
There is no fuse that you need to reset when replacing the ice maker. You should only have to plug it in and it should start working by itself. I suggest that you check the ice maker by manually moving the ejector arm forward slightly. If the ice maker is working properly, the ice maker should then proceed to perform a full cycle. When it gets to the end make sure to check if the water valve is activated and dispenses water into the ice tray.
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 9/27/2022 12:38:23 PM(UTC)
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4/28/2021 11:44:07 AM(UTC)
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4/8/2021 11:13:45 AM(UTC)
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 12/11/2020 4:23:17 PM(UTC)
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 11/14/2020 10:28:34 AM(UTC)
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 4/20/2020 7:26:54 PM(UTC)
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 11/9/2019 3:32:25 PM(UTC)
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 10/19/2019 2:18:49 PM(UTC)
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 9/28/2019 4:41:03 AM(UTC)
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 6/26/2018 11:54:43 AM(UTC)
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 9/17/2017 11:20:17 AM(UTC)
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 9/9/2017 12:46:10 PM(UTC)
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 7/29/2017 8:42:47 AM(UTC)
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 7/21/2017 9:34:37 AM(UTC)
