I am having a problem even the tech I called could not fix. The fridge displays SY EF on the panel which is an Evaporator Fan issue. The tech replaced both the fan and the main board. Still the error code. The fridge section has varied in temp during this but now holds the set temperature. (original fan is now back in the fridge with a new main board)
Over the last three week period, the temp in the fridge has measured anywhere from 42°F to 51°F (as measured with a fridge thermometer)
It has now settled in at the set 37°F for the last couple of days. I cold rebooted the unit and the code was clear for a couple of hours.
The tech said he needed to cut his losses but could not figure out what was wrong. I have emailed Electrolux as to what to do but have heard nothing in two business days.
The tech was listed on Electrolux's website.
The unit is almost 4 years old and is out of warranty.
Any ideas as what to do next would be appreciated.
Kevin
