Discuss
Intermittent Evap Fan or Defrost T-Stat?
 in
Refrigerator & Freezer Repair
I woke up yesterday to find that my freezer was half thawed. The evaporator fan was not spinning. I opened
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Intermittent Evap Fan or Defrost T-Stat?
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 07-14-2014, 12:28 PM
Junior Member
cjaldous is on a distinguished road
Default Intermittent Evap Fan or Defrost T-Stat?
Model Number: SXD26VL   Brand: Amana   Age: More than 10 years
I opened the evaporator compartment and found the top portion iced up, but the fan could spin freely.
After unplugging the fridge, and doing some troubleshooting (see below) I plugged the fridge back in and the fan started working.
The freezer got cold enough to freeze ice, and everything seemed to be working.
I woke up this morning to find the evap fan off again, the freezer half thawed, and the same iced up top coils.
Here's the stuff I checked previously.
Evap Fan: 0.5 Ohm, 120V when on
Defrost TStat: Closed (while on frosted pipe), measured <0.5 Ohm
Defrost Timer: motor spins, and turns compressor/evap fan on/off
Heater Element: 30 Ohm, 120V when on
Compressor Coils: (S-C)10 Ohm, (R-C)2.6Ohm, (S-R) 12.6Ohm
Start Relay: 4 Ohms
Overload: <1 Ohm
Condenser Fan blows when expected
I was about to overnight a defrost thermostat, but figured I'd ask around first.
It's obvious from the wiring that it has been replaced before.
I can only guess that the defrost t-stat has gone intermittent or the fan is intermittent.
I need to try and measure the voltages at the fan terminals the next time I find it stopped.
Any other thoughts?
Related Models
Amana SXD26VL REF - SXS/I&W
Amana SXD26VW REF - SXS/I&W
Amana SXD27NE REF - SXS/I&W
Amana SXD27NL REF - SXS/I&W
Amana SXD27NW REF - SXS/I&W
Amana SXD27Q2E REF - SXS/I&W
Amana SXD27Q2L REF - SXS/I&W
Amana SXD27Q2W REF - SXS/I&W
Amana SXD27TE REF - SXS/I&W
Amana SXD27TL REF - SXS/I&W
Amana SXD27TW REF - SXS/I&W
Amana SXD322L REF - SXS/I&W
Amana SXD322S2L REF - SXS/I&W
Amana SXD322S2W REF - SXS/I&W
Amana SXD322W REF - SXS/I&W
Amana SXD520NW REF - SXS/I&W
Amana SXD520SL REF - SXS/I&W
Amana SXD520SW REF - SXS/I&W
Amana SXD520TE REF - SXS/I&W
Amana SXD520TW REF - SXS/I&W
Amana SXD522VE REF - SXS/I&W
Amana SXD522VW REF - SXS/I&W
Amana SXD524VE REF - SXS/I&W
Amana SXD524VW REF - SXS/I&W
Amana SXDE25J REF - SXS/I&W
Amana SXDE25JB REF - SXS/I&W
Amana SXDE25JP REF - SXS/I&W
Amana SXDE27NE REF - SXS/I&W
Amana SXDE27NL REF - SXS/I&W
Amana SXDE27NPE REF - SXS/I&W
Amana SXDE27NPL REF - SXS/I&W
Amana SXDE27NPW REF - SXS/I&W
Amana SXDE27NW REF - SXS/I&W
Amana SXDE27QE REF - SXS/I&W
Amana SXDE27QL REF - SXS/I&W
Amana SXDE27QW REF - SXS/I&W
Amana SXDE522K REF - SXS/I&W
Amana SXDE522M REF - SXS/I&W
Amana SXDE526K REF - SXS/I&W
Amana SXDE526M REF - SXS/I&W
Amana SXDE528MW REF - SXS/I&W
Amana SXDT22H REF - SXS/I&W
Amana SXDT25H REF - SXS/I&W
Amana SXDT522J REF - SXS/I&W
Amana SXDT522K REF - SXS/I&W
Amana SXDT522M REF - SXS/I&W
Amana SXDT526J REF - SXS/I&W
Amana SXI20J REF - SXS/I&W
Amana SXI20NE REF - SXS/I&W
Amana SXI20NL REF - SXS/I&W
Amana SXI20NW REF - SXS/I&W
Amana SXI25SE REF - SXS/I&W
Amana SXI25SL REF - SXS/I&W
Amana SXI25SW REF - SXS/I&W
Amana SXP22H REF - SXS/I&W
Amana SXP25H REF - SXS/I&W
Amana SXPD20H REF - SXS/I&W
Amana SXPD22H REF - SXS/I&W
Amana SXPD25H REF - SXS/I&W
Amana SZ22MBL REF - SXS/I&W
Amana SZ22MBW REF - SXS/I&W
Amana SZ22ML REF - SXS/I&W
Amana SZ22MW REF - SXS/I&W
Amana SZ22NE REF - SXS/I&W
Amana SZ22NL REF - SXS/I&W
Amana SZ22NW REF - SXS/I&W
Amana SZ25M2L REF - SXS/I&W
Amana SZ25M2W REF - SXS/I&W
Amana SZ25ML REF - SXS/I&W
Amana SZ25MP2L REF - SXS/I&W
Amana SZ25MP2W REF - SXS/I&W
Amana SZ25MPL REF - SXS/I&W
Amana SZ25MPW REF - SXS/I&W
Amana SZ25MW REF - SXS/I&W
Amana SZ25NE REF - SXS/I&W
Amana SZ25NL REF - SXS/I&W
Amana SZ25NW REF - SXS/I&W
Amana SZD20J Ref - SXS/I&W
Amana SZD20K REF - SXS/I&W
Amana SZD20KB REF - SXS/I&W
  #2 (permalink)
Old 07-15-2014, 09:32 AM
Junior Member
Default Update, Solved?
Update:
I caught the fridge "in the act." I came home to find the tops coils frozen, and the evaporator fan off.
The defrost thermostat measured open.
I'll be replacing that today.
  #3 (permalink)
Old 07-16-2014, 08:27 AM
Junior Member
Default Defrost tstat replaced, now freezer isn't cold enough.
Update
I replaced the defrost thermostat yesterday evening and closed everything up.
I found the evap fan this morning still running (unlike the previous 3 mornings), but the freezer wasn't very cold.
I spot checked the walls with infrared and measured 34-35degF.
The fridge was reading about 45degF.
If it still isn't frozen by the time I get home, is it likely a compressor pumping issue?
I was told that if I had a freon leak it wouldn't cold at all.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
trying to defrost top evap need diagrams edfib Refrigerator & Freezer Repair 0 08-03-2013 04:05 PM
trying to defrost top evap need diagrams edfib Refrigerator & Freezer Repair 0 08-03-2013 03:50 PM
Magic Chef Defrost t-stat location johnspoa Refrigerator & Freezer Repair 0 01-09-2013 02:29 PM
defrost t stat was bad but still too warm newtoresrepair Refrigerator & Freezer Repair 5 09-26-2012 01:13 AM
evap coil is freezing up will not defrost Chrisca Refrigerator & Freezer Repair 1 07-18-2011 02:28 AM
