RodH508
#1 Posted : Saturday, June 28, 2014 5:09:50 PM(UTC)
RodH508
I have a side by side Frigidaire. It stopped cooling properly. I cleaned condenser coils. Freezer at 30 degrees, Fridge at 40 degrees, defrost cycling regularly. I replaced control board. Freezer at 40 degrees, Fridge at 50 degrees, defrost is cycling regularly. Compressor, Evap Fan running. Compressor is a little warmer than room temp. No leaks at door gaskets. I have turned thermostats off for a few minutes and restarted. Air seemed colder just after restart but didn't continue getting colder. What's next? Cold controls?
#2 Posted : Sunday, June 29, 2014 7:45:08 AM(UTC)
Remove freezer back panel and describe frost pattern, total heavy frost, or partial.
RodH508
#3 Posted : Sunday, June 29, 2014 10:45:53 AM(UTC)
RodH508
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
RodH508
#4 Posted : Sunday, June 29, 2014 10:47:18 AM(UTC)
RodH508
Partial frost at top of evaporator.
#5 Posted : Sunday, June 29, 2014 1:09:43 PM(UTC)
You have sealed system problems assuming the condenser fan is ok.
RodH508
#6 Posted : Sunday, June 29, 2014 1:43:03 PM(UTC)
RodH508
Condenser fan is running. So you think it's a refrigerant leak or compressor issues. My condenser coils were covered pretty good before I cleaned them.
#7 Posted : Sunday, June 29, 2014 3:37:23 PM(UTC)
Your compressor may be leaking internally due to thermal stress.
RodH508
#8 Posted : Sunday, June 29, 2014 4:16:18 PM(UTC)
RodH508
I was HVAC certified in 2007, I never truly pursued it outside of helping family, due to getting a better position at my job. Do you think it's worth having the compressor replaced? I do recall from school that once you open a sealed appliance system you could have some bad results.
#9 Posted : Monday, June 30, 2014 1:28:57 AM(UTC)
A big no there, not worth it.
RodH508
#10 Posted : Monday, June 30, 2014 7:02:38 AM(UTC)
RodH508
Thanks for all your help ric.
