Discuss
Need help wiring Vinotemp wine cooler. Going nuts trying to figure this out!
 in
Refrigerator & Freezer Repair
I have a Vinotemp VT-27 TS wine cooler that has served me well for around 4 years, and it just
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Need help wiring Vinotemp wine cooler. Going nuts trying to figure this out!
  #1 (permalink)
Old 06-27-2014, 12:25 AM
Junior Member
victor905 is on a distinguished road
Default Need help wiring relay & overload on Vinotemp wine cooler. Going nuts!
Model Number: Vinotemp VT-27 TS   Brand: -other-   Age: 1 - 5 years
I have a Vinotemp VT-27 TS wine cooler that has served me well for around 4 years, and it just recently went out. Well, only the relay and overload, they had the rattling sounds on both, and the wine cooler has the common clicking sound when plugged in. I'm no electrician, but I know I could get this up and running with the help of members on this forum. I have a red wire that goes to the overload, and a blue wire that goes to the relay( I live in the U.S. Wiring may be a little different...). The relay reads QP2 4.7 and has 1 pin that plugs into the blue wire, and the bottom two prongs on the compressor. The overload just has one pin and plugs into the red wire, and to the top single prong on the common of the compressor. So to sum things up I only have a red and a blue wire, unlike other fridges and coolers that have more, maybe to run fans, grounds, or anything else that might need to pass through these. So now the problem Is buying a R&O kit that fits and finding out how to wire it. I found a kit on amazon for about $13 (had really good reviews), I also asked around amazon and was told by several people that this kit worked good on their vinotemp wine coolers and mini fridges, which are pretty much the same. The only problem with this kit is that there are 4 pins on this new relay and I only have one blue wire... So what pin on this relay does this blue wire go on? If anyone out there could help me, I would really appreciate it, I can provide you with all the info needed, thanks.
The part I purchased is in the URL below
http://www.amazon.com/gp/aw/d/B0053F...ls_o00_s00_i00
Related Models
General Electric VISR208DT8WW Washer
General Electric VISR208DTAWW Washer
General Electric VISR309JT5AA Washer
General Electric VISR309JT6AA Washer
General Electric VISR309JT8AA Washer
General Electric VISR309JTAAA Washer
General Electric VJSR2070T2AB Washer
General Electric VJSR2070T2WB Washer
General Electric VJSR2070T3AB Washer
General Electric VJSR2070T3WB Washer
General Electric VJSR2070T5AB Washer
General Electric VJSR2070T5WB Washer
General Electric VJSR2070T6AB Washer
General Electric VJSR2070T6WB Washer
General Electric VJSR2070T8AB Washer
General Electric VJSR2070T8WB Washer
General Electric VJSR2070TAAB Washer
General Electric VJSR2070TAWB Washer
Gaggenau VK111-610
Gaggenau VK230-610
General Electric VKSR2100T2WW Washer
General Electric VKSR2100T3WW Washer
General Electric VKSR2100T5WW Washer
General Electric VKSR2100T6WW Washer
General Electric VKSR2100T8WW Washer
General Electric VKSR2100TAWW Washer
General Electric VKXR4100T2WW Washer
General Electric VKXR4100T3WW Washer
General Electric VKXR4100T5WW Washer
General Electric VKXR4100T6WW Washer
General Electric VKXR4100T8WW Washer
General Electric VKXR4100TAWW Washer
Gaggenau VL021-707
Gaggenau VL022-707
Gaggenau VL023-707
Gaggenau VL030-707
Gaggenau VL031-707
Gaggenau VL040-707
Gaggenau VL041-707
Gaggenau VL051-707
Gaggenau VL330-707
Gaggenau VL331-707 211100 UP
Gaggenau VL331-707upto 211099
General Electric VLD4209L15BB Dishwasher
General Electric VLD4209L15SS Dishwasher
General Electric VLD4209L15WW Dishwasher
General Electric VLD4209L20BB DISHWASHER
General Electric VLD4209L20SS DISHWASHER
General Electric VLD4209L20WW DISHWASHER
General Electric VLLR1020T0WO Washer
General Electric VLLR1020T1WO Washer
General Electric VLSR1090G0WW Washer
General Electric VLSR1090G2WW Washer
General Electric VLXR1020A0WO Washer
General Electric VLXR1020A1WO Washer
General Electric VLXR1020A2WO Washer
General Electric VLXR1020A3WO Washer
General Electric VLXR1020A4WO Washer
General Electric VLXR1020A4WW Washer
General Electric VLXR1020A5WO Washer
General Electric VLXR1020D0WO Washer
General Electric VLXR1020D2WO Washer
General Electric VLXR1020D5WO Washer
General Electric VLXR1020T2WB Washer
General Electric VLXR1020T3WB Washer
General Electric VLXR1020T4WB Washer
General Electric VLXR1020T5WB Washer
General Electric VLXR1020T8WB Washer
General Electric VLXR1020TAWB Washer
Thermador VM-275
Thermador VM-300
Thermador VM-350
Thermador VM-400
Thermador VM-410 HOOD VENTILATOR
Thermador VM-450
Magic Chef VM11A-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11B-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11B-8PDY MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11BN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11C-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11CN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11D-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11D-8P-DY MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11DN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11EB-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11EV-8P MWAVE- MOUNTED UNDER CABINET
Maytag VM12AB MWAVE- MOUNTED UNDER CABINET
Maytag VM12AM MWAVE- MOUNTED UNDER CABINET
Maytag VM12AV MWAVE- MOUNTED UNDER CABINET
Maytag VM12AV-1 MWAVE- MOUNTED UNDER CABINET
Thermador VM410
Magic Chef VM9B-8 MWAVE- MOUNTED UNDER CABINET
Frigidaire VP21AW3 Tap(v1) / Gas Range
Frigidaire VP21AW3-23 Tap(v2) / Gas Range
Frigidaire VP21AW4 Tap(v3) / Gas Range
Frigidaire VP21AW4-23 Tap(v4) / Gas Range
Frigidaire VP30AW3 Tap(v1) / Gas Range
Frigidaire VP30AW3-23 Tap(v2) / Gas Range
Frigidaire VP30AW4 Tap(v3) / Gas Range
Frigidaire VP30AW4-23 Tap(v4) / Gas Range
Frigidaire VP30BW2 Tap(v1) / Gas Range
Frigidaire VP30BW2-23 Tap(v2) / Gas Range
Frigidaire VP30BW3 Tap(v3) / Gas Range
Frigidaire VP30BW3-23 Tap(v4) / Gas Range
Frigidaire VP30CW2 Tap(v1) / Gas Range
Frigidaire VP30CW2-23 Tap(v2) / Gas Range
Frigidaire VP30CW3 Tap(v3) / Gas Range
Frigidaire VP30CW3-23 Tap(v4) / Gas Range
Frigidaire VP36DW2 Tap(v1) / Gas Range
Frigidaire VP36DW2-23 Tap(v2) / Gas Range
Frigidaire VP36DW3 Tap(v3) / Gas Range
Frigidaire VP36DW3-23 Tap(v4) / Gas Range
Thermador VQT1000 VENTILATOR
Thermador VQT600 VENTILATOR
Thermador VR-1000 VENTILATOR
Thermador VR-1400 VENTILATOR
Thermador VR-600
Thermador VR1000
Gaggenau VR122-612
Thermador VR1400
Last edited by victor905 : 06-27-2014 at 12:47 AM. Reason: Needed more detail and pictures
  #2 (permalink)
Old 06-27-2014, 02:07 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Need a picture the new start device.
__________________
  #3 (permalink)
Old 06-27-2014, 02:10 AM
Senior Expert
APP Volunteer
Default
I also need you to measure the ohms of the old start ptc device shown.
__________________
  #4 (permalink)
Old 06-27-2014, 03:37 AM
Junior Member
Default New start device pictures and URL links to product
I just ordered this new relay and overload off of amazon 3 days ago (it should be coming in soon), so I can't actually take a picture of the new relay itself. These are the pictures provided by amazon and appliancepartspros.
The part number is Whirlpool 4387913 it comes in a kit with a relay and overload
http://www.amazon.com/gp/aw/d/B0053F...&robot_redir=1
This is the appliancepartspros same product:
Whirlpool 4387913 Overload - AppliancePartsPros.com
Sorry for the bad pictures it's all I have to work with right now, until the part gets here.
  #5 (permalink)
Old 06-27-2014, 03:53 AM
Junior Member
Default
As for the ohms on the old start relay, I removed the relay after the picture, and it was no good at all. It had small pieces of the ceramic element inside... I measured the actual prongs on the compressor to check if the compressor was grounding, or if the compressor is still good, and it seems it's still good. I can't find much about the original relay all I know about it is it has QP2-4.7 on it and it has one single terminal (next to a 2 marked on the relay) and the blue wire was attached to this one.
Here is a better picture of the old relay with 1 terminal:
  #6 (permalink)
Old 06-27-2014, 04:25 AM
Senior Expert
APP Volunteer
Default
Hold the old ptc device with the input, spade terminals facing you and the tab on top. If you measure zero ohms from the right input terminal and the output, right, compressor terminal, you have the standard compressor pinnout, start winding, lower left, run winding, lower right.
One fridg power wire goes to the right input terminal of the ptc device, the other to the overload.
The new ptc device should measure the same as the old one, except you should measure 5 to 10 ohms from the right input terminal and the left, compressor output terminal.
Any difference between the old and new ptc pinnout will ensure compressor burnout!
__________________
  #7 (permalink)
Old 01-08-2018, 09:43 AM
Junior Member
niderman is on a distinguished road
Default Resolution?
Hello,
To the original poster, victor905...So, what was the ultimate resolution in laymen terms? I have the same issue, and would like to know what wires to plug in where on the new relays.
Thank you,
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wine Cooler mike.belleville@cmadishma Refrigerator & Freezer Repair 1 01-26-2013 12:31 AM
wine cooler Mc pappy Refrigerator & Freezer Repair 1 07-12-2011 02:31 AM
wine cooler linlin Refrigerator & Freezer Repair 1 02-21-2011 02:26 AM
Need wiring diagram for Wine Cooler steve_c Refrigerator & Freezer Repair 6 03-27-2010 02:54 PM
wine cooler Ron 988 Refrigerator & Freezer Repair 0 09-18-2007 07:57 PM
