The model # is RT21LMXKQ02
The unit works fine except there is water inside that drains inside the unit and has to be dipped out. It runs on the floor if it is not dipped. Sometimes I put a cup under the tube where it drips to catch the water. Is something stopped up or what? Tell me the best way to remedy this problem.:confused:
