No Ice. Replaced icemaker, no Ice. Replaced Water control solenoid, No Ice.
Verified water pressure, got water from the water dispenser no problem. When replacing water control valve made sure I could blow through the icemaker line (no obstruction). Verified that the blinking light goes solid when I manually close the flap... Tire of replacing good parts WHAT AM I MISSING?
How to manually make that rascal fill to test the fill valve I just replaced?
HELP!
