I have a Whirlpool ED22RF side by side. I just replaced the water valve successfully, however upon first testing I am getting a leak on a tube that I'm not able to identify in the schematics you have available. If you go to the video for the condenser fan motor: Whirlpool 4387244 Condenser Fan Motor Assembly - AppliancePartsPros.comAt the 1:04 mark of that video on the left of the screen there are two white water tubes - one of which is zip tied to a copper line. One or both of those are leaking on my fridge very slowly until the water dispenser is activated and then the leak gets stronger. I need help figuring out how to replace those and where do they go? Can anyone help point me in the right direction? Thank you in advance.
