We had a leak under our fridge. My husband tracked it down to a small crack in one of the water tubes (8201597). We ordered replacement part AP3607291. When my husband went to install the new hose, the compression valve fit fine, but the hose end that inserts into the push-in connection is too small. Is there another option?
