THE ice dispenser on the front of the refrig does not work. Water works fine. ice is being released into door chute but flap to release ice doesn't work. Ice sits in door and melts, has caused some rusting of screws. Is this fixable. Understand there may be a "solinoid"(sp?) problem in door which is not allowing the door flap to open and close properly. Also there is frost on the inside of the door ice chute. Can we repair ourselves using the schematic you have on site or is it very complicated. Which parts would fix???Thanks for your help.
