Have an Amana refrig. Model# DRS2662AW and Serial# PDRS2662AWD
Last year replaced the main water valve. Now the problem is the water dispenser in the door. Sometimes the switch or valve does not turn the water off right away after you remove your glass from the dispenser. So keeps running for a couple seconds.
Sounds like a micro switch is sticking. Don't hear it click.
Anyway would like to try that part first. But don't have a part number and unsure how to get to the part. Take the back of the freezer door maybe?
