Hello I have a Viking Range Beverage Fridge Model No.: VUAR1431TLSS Serial No.: 201110323106H Here is the manual: http://media.datatail.com/docs/installation/76195_en.pdfand when I plug power the fridge does not make a sound. On the temp control display inside the fridge it only display two dash lines where the temperature is suppose to be. What does the two dash lines mean? I can't find it in the manual. When open up the display and reconnect the data cable, but not all the way to the click the condenser and the fan would start up. But there is nothing on the display. It is has no light and blank. If I leave it like that with the door closed it would reach up to 35 degree Fahrenheit (I placed a regular thermometer inside). How can I fix my fridge so I can see the temperature on display and control it? Could I be the display board, data cable, and the control board, air or evap sensor? The same result would appear if I have both sensors connected or disconnected. I check the sensors do receive 5-volt power. Sorry for a long detailed question. I hope someone has already experienced this problem. Thank you in advance.
