The ice maker is located in the upper left hand corner of the refrigerator section on this Frigidaire French door refrig. How do you remove the plastic cover around the ice maker. It has to be removed first to facilitate removal of ice maker assembly. There are three screws on the left side of this cover that releases the left side, but how is right side attached. This model does not have your typical ice maker. Because it is located in the refrigerator section, it has a separate evaporator to cool the ice mold. Need to remove ice maker to replace broken part. Any help would be appreciated.
