Discuss
Ice Maker Replacement Water Valve -Kemore/Whirlpool
 in
Refrigerator & Freezer Repair
My refrigerator has a door ice and water dispenser. The water supply valve is bad. The original valve (part # 2205762)
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Ice Maker Replacement Water Valve -Kemore/Whirlpool
  #1 (permalink)
Old 02-15-2008, 03:38 PM
Pat Mounicou Pat Mounicou is offline
Junior Member
Pat Mounicou is on a distinguished road
Cool Ice Maker Replacement Water Valve -Kemore/Whirlpool
Model Number: 106.59297993   Brand: Kenmore   Age: 5 - 10 years
My refrigerator has a door ice and water dispenser. The water supply valve is bad. The original valve (part # 2205762) is designed for compression fitting water lines. However, it is no longer manufactured. The replacement water valve (part # 2304833) uses quick disconnect lines. Do I need to replace all of the water lines or is there some type of adapter that can be used to convert from compression fittings to the quick disconnect fittings?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore water inlet valve replacement sallag Refrigerator & Freezer Repair 0 01-25-2008 08:35 AM
Which ice maker water valve to order? blazindaily Refrigerator & Freezer Repair 12 01-17-2008 06:08 PM
Ice maker Valve normdyer Refrigerator & Freezer Repair 2 01-12-2008 02:33 PM
Ice Maker water valve Jaye Refrigerator & Freezer Repair 1 12-11-2007 06:26 PM
Water Valve Replacement Cary Washer Repair 3 11-07-2007 12:31 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
