I was replacing a leaking water valve and noticed that the water lines into the valve were dry and brittle and broke off. I need some 5/16 and 1/4 inch water lines and quick connectors. Surprisingly these are harder to find on the site than the water valve. Can anyone suggest a decent kit so I can replace about a foot of each line with a new one using the quick connectors. Thanks for your advice.
