My new freezer just arrived. It's on and cooling well so far - its been on for a couple hours now; however, I have not inserted the air baffle which will point the air upward or downward depending on which way you insert the baffle. I don't want to insert it upside down and cannot find anything in the paperwork that came with the freeze that indicates which way to point the air. The location of this baffle is inside the top rear of freezer, smack dab in front of one's face when the door is opened. It just pushes into the interior wall of the freezer. I would think to have the air flowing down but I suppose pushing the air up could increase overall circulation. Can someone please advise that proper way to push that little baffle into the wall? Thanks.
