Discuss
Freezer only cooling to 30 degrees
 in
Refrigerator & Freezer Repair
I noticed some water on the floor and opened freezer door to find the ice melting in the ice maker.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Freezer only cooling to 30 degrees
  #1 (permalink)
Old 04-12-2014, 02:14 PM
Junior Member
pepq105 is on a distinguished road
Question Freezer only cooling to 30 degrees
Model Number: SZD25NL   Brand: Amana   Age: 5 - 10 years
I put a thermometer in the freezer and only cooling to 30 degrees.
The thing is running continuously also.
I cleaned the condenser coils and condenser fan is operating along with the evaporator fan.
The units defrost test mode operates correctly and evap heater is working.
The 2 items I'm thinking might be the problem I can't find any info on how to test them.
1. Freezer temp thermostat
2. Compressor running
Any help?
Related Models
Amana SZD25NL REF - SXS/I&W
Amana SZD25NW REF - SXS/I&W
Amana SZD25S5E REF - SXS/I&W
Amana SZD25S5L REF - SXS/I&W
Amana SZD25S5W REF - SXS/I&W
Amana SZD26VE REF - SXS/I&W
Amana SZD26VL REF - SXS/I&W
Amana SZD26VW REF - SXS/I&W
Amana SZD27KBL REF - SXS/I&W
Amana SZD27KBW REF - SXS/I&W
Amana SZD27KL REF - SXS/I&W
Amana SZD27KPL REF - SXS/I&W
Amana SZD27KPW REF - SXS/I&W
Amana SZD27KW REF - SXS/I&W
Amana SZD27MBL REF - SXS/I&W
Amana SZD27MBW REF - SXS/I&W
Amana SZD27ML REF - SXS/I&W
Amana SZD27MPB REF - SXS/I&W
Amana SZD27MPL REF - SXS/I&W
Amana SZD27MPW REF - SXS/I&W
Amana SZD27MW REF - SXS/I&W
Amana SZD27NE REF - SXS/I&W
Amana SZD27NL REF - SXS/I&W
Amana SZD27NW REF - SXS/I&W
Amana SZDE20K REF - SXS/I&W
Amana SZDE20K Ref - SXS/I&W
Amana SZDE20KB REF - SXS/I&W
Amana SZDE20KB Ref - SXS/I&W
Amana SZDE20KP REF - SXS/I&W
Amana SZDE20KP Ref - SXS/I&W
Amana SZDE20MBL REF - SXS/I&W
Amana SZDE20MBW REF - SXS/I&W
Amana SZDE20ML REF - SXS/I&W
Amana SZDE20MPE REF - SXS/I&W
Amana SZDE20MPL REF - SXS/I&W
Amana SZDE20MPW REF - SXS/I&W
Amana SZDE20MW REF - SXS/I&W
Amana SZDE25K REF - SXS/I&W
Amana SZDE25KB REF - SXS/I&W
Amana SZDE25KP REF - SXS/I&W
Amana SZDE25MBL REF - SXS/I&W
Amana SZDE25MBW REF - SXS/I&W
Amana SZDE25ML REF - SXS/I&W
Amana SZDE25MPE REF - SXS/I&W
Amana SZDE25MPL REF - SXS/I&W
Amana SZDE25MPW REF - SXS/I&W
Amana SZDE25MW REF - SXS/I&W
Amana SZDE27KBL REF - SXS/I&W
Amana SZDE27KBW REF - SXS/I&W
Amana SZDE27KL REF - SXS/I&W
Amana SZDE27KPL REF - SXS/I&W
Amana SZDE27KPW REF - SXS/I&W
Amana SZDE27KW REF - SXS/I&W
Amana SZDE27MBL REF - SXS/I&W
Amana SZDE27MBW REF - SXS/I&W
Amana SZDE27ML REF - SXS/I&W
Amana SZDE27MPE REF - SXS/I&W
Amana SZDE27MPL REF - SXS/I&W
Amana SZDE27MPW REF - SXS/I&W
Amana SZDE27MW REF - SXS/I&W
Amana SZDE27NE REF - SXS/I&W
Amana SZDE27NL REF - SXS/I&W
Amana SZDE27NW REF - SXS/I&W
Amana SZI20K REF - SXS/I&W
Amana SZI20ML REF - SXS/I&W
Amana SZI20MW REF - SXS/I&W
Amana SZI20NE REF - SXS/I&W
Amana SZI20NL REF - SXS/I&W
Amana SZI20NW REF - SXS/I&W
Amana T-17D MISC / ACCESSORY
Amana T-17D-1 MISC / ACCESSORY
Amana T-17E MISC / ACCESSORY
Amana T-17LD MISC / ACCESSORY
Amana T-17LD-1 MISC / ACCESSORY
Amana T-17LE MISC / ACCESSORY
Hoover T1001-1
Hoover T1003
Hoover T1003-1
Hoover T1003-2
Hoover T1003-4
Hoover T1003-5
Hoover T1003-6
Hoover T1009-1
Hoover T1009-2
Hoover T1009-5
Hoover T1011
Hoover T1011-1
Hoover T1011-161
Hoover T1011-6
Hoover T1011-664
Hoover T1023
Hoover T1023-1
Hoover T1023-2
Hoover T1023-5
Hoover T1023-6
  #2 (permalink)
Old 04-13-2014, 02:24 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for Amana SZD25NL / P1162403W L - AppliancePartsPros.com
You said that the unit is running continuously.
I am assuming that you mean the compressor.
You can usually hear it but should also be able to feel it vibrating.
If the above is true then:
The thermostat is OK as it is running the compressor trying to lower the temperature to the set point temperature.
The compressor or sealed system is the problem. It is running but for some reason cannot lower the temperature to the set point.
I am assuming that there is little or no frost on the evaporator/freezer coils since you said the defrost heater works and did not say that they were clogged solid with ice/frost.
A sealed system problem will be an expensive reapir as you need a pro.
Often it makes more sense to put those dollars towards a new fridge.
__________________
  #3 (permalink)
Old 04-13-2014, 04:00 AM
Junior Member
Default
I'm not sure if the compressor is running.
When I said running the condenser fan and evap fans are both running.
The evap isn't clogged solid with ice.
I could not find a wiring diagram to see if the temp control thermostat controls both fans and compressor?
  #4 (permalink)
Old 04-13-2014, 07:10 AM
Senior Expert
APP Volunteer
Default
I also could not find a wiring diagram but the norm is that the compressor and it's fan are on at the same time.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer only cooling to 20 degrees F Ron B Refrigerator & Freezer Repair 18 10-29-2017 03:52 AM
Fridge is warm 54 degrees and freezer is 7 degrees kassull Refrigerator & Freezer Repair 0 08-15-2012 02:50 PM
Freezer -4 degrees and refrigerator 48 degrees FDAR Refrigerator & Freezer Repair 0 11-19-2011 03:58 PM
Freezer @ 15 degrees refrigerator @37 degrees mfoxgrover Refrigerator & Freezer Repair 2 10-05-2010 02:54 PM
Freezer 0 degrees, fridge 55 degrees. repairmystuff Refrigerator & Freezer Repair 0 07-17-2010 11:04 AM
