Discuss
freezer doesn't get cold anymore
 in
Refrigerator & Freezer Repair
Freezer doesn't get cold at all. Compressor too hot to hold my hand on it but it runs. Unplugged it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » freezer doesn't get cold anymore
  #1 (permalink)
Old 04-09-2014, 03:29 PM
Junior Member
clank is on a distinguished road
Question freezer doesn't get cold anymore
Brand: GE   Age: 1 - 5 years
Freezer doesn't get cold at all. Compressor too hot to hold my hand on it but it runs. Unplugged it for 48 hours then plugged it back in, same thing. Bought this from Home Depot along with refrigerator. Now both have had problems.
  #2 (permalink)
Old 04-11-2014, 05:21 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help others help you.
Find your model number - AppliancePartsPros.com
Is the compressor vibrating?
Is there a condenser/compressor fan?
If there is, is the fan on?
Below is a link to how to check compressor windings.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
Note that this is not a definitive test.
It will tell you if a compressor is bad but does not tell you that the compressor is good as it may have winding to winding shorts or mechanical problems.
Same goes for a capacitor as they may only fail when actual working voltage (120 volts) is applied to them.
If the start device seems OK mechanically then the only good way to check for a problem is to give a new one a try.
__________________
  #3 (permalink)
Old 04-22-2014, 06:37 PM
Junior Member
Default
Brand- GE Model # FUF 21 SVDRWW Compreesor does vibrate, nocompressor fan
  #4 (permalink)
Old 04-23-2014, 11:24 AM
Senior Expert
APP Volunteer
Default
Parts for GE FUF21SVDRWW Freezer - AppliancePartsPros.com
Since the compressor is running and you get no cooling at all I would say that it is a sealed system problem.
This will be an expensive repair and often it makes more sense to put the dollars towards a new unit.
I would check your warranty as sometimes the sealed system has a longer warranty that just one year.
I am assuming that the evaporator fan in the freezer is running.
It should be on whenever the compressor is on.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer & Fridge Both not cold anymore s3curityplu5 Refrigerator & Freezer Repair 0 08-18-2012 03:11 PM
GE freezer won't keep Ice Frozen anymore PamM Refrigerator & Freezer Repair 0 06-15-2011 01:15 PM
Frigerator not keeping very cold anymore mrbeachroach Refrigerator & Freezer Repair 1 07-31-2010 08:55 PM
GE fridge/freezer freezer is defrosting and not freezing anymore booomer Refrigerator & Freezer Repair 1 04-06-2009 05:32 AM
freezer won't freeze anymore 1967hammer Refrigerator & Freezer Repair 3 09-10-2008 06:25 PM
