Discuss
frigidaire upright freezer
 in
Refrigerator & Freezer Repair
The alarm came on and the top 2 shelves are not freezing as solid as bottom of freezer is. Both
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » frigidaire upright freezer
  #1 (permalink)
Old 04-09-2014, 07:22 AM
Junior Member
mmanning is on a distinguished road
Default frigidaire upright freezer
Model Number: LFFH2067DW1   Brand: Frigidaire   Age: 5 - 10 years
The alarm came on and the top 2 shelves are not freezing as solid as bottom of freezer is. Both the orange and red indicator lights are on. The freezer has been making loud bumping noises sparatically for a few weeks past.
Related Models
Frigidaire LFFH2067DW1 Frigidaire/freezer
Frigidaire LFFH2067DW2 Frigidaire/freezer
Frigidaire LFFH2067DW3 FREEZER
Frigidaire LFFH2067DW4 FREEZER
Frigidaire LFFH2067DW6 FREEZER
Frigidaire LFFH2067DW7 FREEZER
Frigidaire LFFH21F7HWA FREEZER
Frigidaire LFFH21F7HWB FREEZER
Frigidaire LFFH21F7HWC FREEZER
Frigidaire LFFH21F7HWD FREEZER
Frigidaire LFFH21F7HWE FREEZER
Frigidaire LFFH21F7HWF FREEZER
Frigidaire LFFH21F7HWG FREEZER
Frigidaire LFFH21F7HWH FREEZER
Frigidaire LFFH21F7HWJ FREEZER
Frigidaire LFFN15M5HWA FREEZER
Frigidaire LFFN15M5HWB FREEZER
Frigidaire LFFU1153DW0 Frigidaire/freezer
Frigidaire LFFU1153DW1 Frigidaire/freezer
Frigidaire LFFU1153DW2 Frigidaire/freezer
Frigidaire LFFU1153DW3 Frigidaire/freezer
Frigidaire LFFU1424DW0 Frigidaire/freezer
Frigidaire LFFU1424DW1 Frigidaire/freezer
Frigidaire LFFU1424DW10 FREEZER
Frigidaire LFFU1424DW11 FREEZER
Frigidaire LFFU1424DW12 FREEZER
Frigidaire LFFU1424DW13 FREEZER
Frigidaire LFFU1424DW14 FREEZER
Frigidaire LFFU1424DW15 FREEZER
Frigidaire LFFU1424DW16 FREEZER
Frigidaire LFFU1424DW2 Frigidaire/freezer
Frigidaire LFFU1424DW3 Frigidaire/freezer
Frigidaire LFFU1424DW4 Frigidaire/freezer
Frigidaire LFFU1424DW5 Frigidaire/freezer
Frigidaire LFFU1424DW6 FREEZER
Frigidaire LFFU1424DW7 FREEZER
Frigidaire LFFU1424DW8 FREEZER
Frigidaire LFFU1424DW9 FREEZER
Frigidaire LFFU1465DW0 Frigidaire/freezer
Frigidaire LFFU1465DW1 Frigidaire/freezer
Frigidaire LFFU1465DW2 Frigidaire/freezer
Frigidaire LFFU1465DW3 Frigidaire/freezer
Frigidaire LFFU1465DW4 Frigidaire/freezer
Frigidaire LFFU1465DW5 Frigidaire/freezer
Frigidaire LFFU1465DW6 Frigidaire/freezer
Frigidaire LFFU1466GW0 FREEZER
Frigidaire LFFU1466GW1 FREEZER
Frigidaire LFFU1466GW2 FREEZER
Frigidaire LFFU1466GW3 FREEZER
Frigidaire LFFU14F5HWA FREEZER
Frigidaire LFFU14F5HWB FREEZER
Frigidaire LFFU14F5HWC FREEZER
Frigidaire LFFU14F5HWD FREEZER
Frigidaire LFFU14F5HWE FREEZER
Frigidaire LFFU14F5HWF FREEZER
Frigidaire LFFU14F5HWG FREEZER
Frigidaire LFFU14F5HWH FREEZER
Frigidaire LFFU14F5HWJ FREEZER
Frigidaire LFFU14F5HWK FREEZER
Frigidaire LFFU14F5HWL FREEZER
Frigidaire LFFU14F5HWM FREEZER
Frigidaire LFFU14F5HWN FREEZER
Frigidaire LFFU1765DW0 Frigidaire/freezer
Frigidaire LFFU1765DW1 Frigidaire/freezer
Frigidaire LFFU1765DW11 Frigidaire/freezer
Frigidaire LFFU1765DW12 Frigidaire/freezer
Frigidaire LFFU1765DW13 Frigidaire/freezer
Frigidaire LFFU1765DW14 Frigidaire/freezer
Frigidaire LFFU1765DW15 Frigidaire/freezer
Frigidaire LFFU1765DW16 FREEZER
Frigidaire LFFU1765DW2 Frigidaire/freezer
Frigidaire LFFU1765DW3 Frigidaire/freezer
Frigidaire LFFU1765DW4 Frigidaire/freezer
Frigidaire LFFU1765DW5 Frigidaire/freezer
Frigidaire LFFU1765DW6 Frigidaire/freezer
Frigidaire LFFU1765DW8 Frigidaire/freezer
Frigidaire LFFU1765DW9 Frigidaire/freezer
Frigidaire LFFU1766GW1 FREEZER
Frigidaire LFFU1766GW2 FREEZER
Frigidaire LFFU1766GW3 FREEZER
Frigidaire LFFU1766GW4 FREEZER
Frigidaire LFFU17F5HWA FREEZER
Frigidaire LFFU17F5HWB FREEZER
Frigidaire LFFU17F5HWC FREEZER
Frigidaire LFFU17F5HWD FREEZER
Frigidaire LFFU17F5HWE FREEZER
Frigidaire LFFU17F5HWF FREEZER
Frigidaire LFFU17F5HWG FREEZER
Frigidaire LFFU17F5HWH FREEZER
Frigidaire LFFU17F5HWJ FREEZER
Frigidaire LFFU17F5HWK FREEZER
Frigidaire LFFU17F5HWL FREEZER
Frigidaire LFFU2065DW0 Frigidaire/freezer
Frigidaire LFFU2065DW1 Frigidaire/freezer
Frigidaire LFFU2065DW10 Frigidaire/freezer
Frigidaire LFFU2065DW2 Frigidaire/freezer
Frigidaire LFFU2065DW3 Frigidaire/freezer
Frigidaire LFFU2065DW4 Frigidaire/freezer
Frigidaire LFFU2065DW5 Frigidaire/freezer
Frigidaire LFFU2065DW6 Frigidaire/freezer
Frigidaire LFFU2065DW7 Frigidaire/freezer
Frigidaire LFFU2065DW8 Frigidaire/freezer
Frigidaire LFFU2065DW9 Frigidaire/freezer
Frigidaire LFFU2067DS0 Frigidaire/freezer
Frigidaire LFGF3014LBA GAS RANGE
Frigidaire LFGF3014LBB GAS RANGE
Frigidaire LFGF3014LBC GAS RANGE
Frigidaire LFGF3014LWA GAS RANGE
Frigidaire LFGF3014LWB GAS RANGE
Frigidaire LFGF3014LWC GAS RANGE
Frigidaire LFGF3022LSA GAS RANGE
Frigidaire LFGF3022LSB GAS RANGE
Frigidaire LFGF3022LSC GAS RANGE
Frigidaire LFGF3022LSD GAS RANGE
Frigidaire LFGF3022LWA GAS RANGE
Frigidaire LFGF3022LWC GAS RANGE
Frigidaire LFGF3027LBA GAS RANGE
Frigidaire LFGF3027LBB GAS RANGE
Frigidaire LFGF3027LSA GAS RANGE
Frigidaire LFGF3027LSB GAS RANGE
  #2 (permalink)
Old 04-09-2014, 08:44 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here are your parts.
Parts for Frigidaire LFFH2067DW1 Freezer - AppliancePartsPros.com
Is the evaporator/freezer fan on when the door switch is held closed?
If the fan is not working the warm air will rise in the cabinet.
Is the compressor on?
You can usually hear it but should also be able to feel it vibrating?
If on is it cycling normally or is it on all the time?
If it is on remove the cover in the freezer to inspect the evaporator coils.
If they are heavily frosted/iced over you may have a defrost problem.
The compressor will probably run all the time except when it goes through a defrost cycle.
If there is just frost in one area (usually where the freon enters the coils) it could be a sealed system problem. The compressor will also run all the time.
I am not sure what the bumping noise is.
Sometimes if there is a mechanical problem with the compressor there will be a bang when the compressor shuts off.
May just be a bad compressor mount so I would check them.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire upright freezer alarms Spydrfly Refrigerator & Freezer Repair 2 05-23-2014 04:43 PM
Frigidaire Upright Freezer Foor Refrigerator & Freezer Repair 1 10-21-2013 02:59 PM
Frigidaire upright freezer not freezing bmorgan001 Refrigerator & Freezer Repair 1 08-12-2012 03:17 AM
Frigidaire Upright Freezer jrann1 Refrigerator & Freezer Repair 1 02-14-2009 02:57 PM
