Discuss
Refriderator stop working
 in
Refrigerator & Freezer Repair
My refrigerator/freezer just stopped working. Only the light inside the fridge still works but the fan and compressor do not.
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refriderator stop working
  #1 (permalink)
Old 03-30-2014, 12:46 PM
Junior Member
Yuan is on a distinguished road
Default Refriderator stop working
Model Number: TPX25PR   Brand: GE   Age: More than 10 years
My refrigerator/freezer just stopped working. Only the light inside the fridge still works but the fan and compressor do not. How to I determine if it is the defrost timer, relay, overload or compressor that is the problem?
Related Models
Amana TQ18NB REF - TOP MOUNT
Amana TQ18QB2L REF - TOP MOUNT
Amana TQ18QB2W REF - TOP MOUNT
Amana TQ18QBG REF - TOP MOUNT
Amana TQ18QBL REF - TOP MOUNT
Amana TQ18QBW REF - TOP MOUNT
Amana TQ18R2G REF - TOP MOUNT
Amana TQ18R2L REF - TOP MOUNT
Amana TQ18R2W REF - TOP MOUNT
Amana TQ18R3G REF - TOP MOUNT
Amana TQ18R3L REF - TOP MOUNT
Amana TQ18R3W REF - TOP MOUNT
Amana TQ18RBG REF - TOP MOUNT
Amana TQ18RBL REF - TOP MOUNT
Amana TQ18RBW REF - TOP MOUNT
Amana TQ20NB REF - TOP MOUNT
Amana TQ20QBG REF - TOP MOUNT
Amana TQ20QBL REF - TOP MOUNT
Amana TQ20QBW REF - TOP MOUNT
Amana TQ22NB REF - TOP MOUNT
Amana TQ22QBG REF - TOP MOUNT
Amana TQ22QBL REF - TOP MOUNT
Amana TQ22QBW REF - TOP MOUNT
Amana TR-17D MISC / ACCESSORY
Amana TR-17D-1 MISC / ACCESSORY
Amana TR-17E MISC / ACCESSORY
Amana TR-17LD MISC / ACCESSORY
Amana TR-17LD-1 MISC / ACCESSORY
Amana TR-17LE MISC / ACCESSORY
Amana TR-19D MISC / ACCESSORY
Amana TR-19E MISC / ACCESSORY
Amana TR-19LD MISC / ACCESSORY
Amana TR-19LE MISC / ACCESSORY
Amana TR15-G MISC / ACCESSORY
Amana TR15F-1 MISC / ACCESSORY
Amana TR15F-1-A MISC / ACCESSORY
Amana TR15F-1-AG MISC / ACCESSORY
Amana TR15F-1-C MISC / ACCESSORY
Amana TR15G REF - TOP MOUNT
Amana TR15G-A REF - TOP MOUNT
Amana TR15G-AG REF - TOP MOUNT
Amana TR15G-C REF - TOP MOUNT
Amana TR16B REF - TOP MOUNT
Amana TR16B-A REF - TOP MOUNT
Amana TR16B-C REF - TOP MOUNT
Amana TR16B-G REF - TOP MOUNT
Amana TR16B-L REF - TOP MOUNT
Amana TR16G REF - TOP MOUNT
Amana TR16H REF - TOP MOUNT
Amana TR16J MISC / ACCESSORY
Amana TR16J REF - TOP MOUNT
Amana TR16J-A MISC / ACCESSORY
Amana TR16J-A REF - TOP MOUNT
Amana TR16J-AG MISC / ACCESSORY
Amana TR16J-AG REF - TOP MOUNT
Amana TR16J-C MISC / ACCESSORY
Amana TR16J-C REF - TOP MOUNT
Amana TR16K REF - TOP MOUNT
Amana TR16N MISC / ACCESSORY
Amana TR16N-A MISC / ACCESSORY
Amana TR16N-AG MISC / ACCESSORY
Amana TR16N-C MISC / ACCESSORY
Amana TR16W MISC / ACCESSORY
Amana TR16W-A MISC / ACCESSORY
Amana TR16W-AG MISC / ACCESSORY
Amana TR16W-C MISC / ACCESSORY
  #2 (permalink)
Old 03-31-2014, 04:28 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Parts for TPX25PR - AppliancePartsPros.com
You are missing digits at the end so will have to choose the correct model from the Matching Model Numbers section.
Since the condenser/compressor fan are both off it will not be the start relay or the overload as the compressor and fan are usually wired in parallel so neither part is getting power.
That leaves you with the control thermostat or the defrost timer.
Try moving the thermostat back and forth. If it fires up then it is the most likely cause.
If this does nothing.
Turn the defrost timer cam with a screwdriver. There is usually a hole in the cover that allows you to do this without dismantling the unit. If it fires up I would replace the timer.
__________________
  #3 (permalink)
Old 03-31-2014, 05:50 AM
Junior Member
Default
Thank you, Denman,
I moved the thermostat a bit and it worked!
Do I need to replace the thermostat now or will it happen again?
My GE Profile model number is TFX25PRYFWW.
Thanks again,
yuan
  #4 (permalink)
Old 03-31-2014, 08:15 AM
Senior Expert
APP Volunteer
Default
If it happened once, it will happen again so I would replace it.
__________________
  #5 (permalink)
Old 03-31-2014, 09:01 AM
Junior Member
Default
Is this the right replacement thermostat I should buy?
GE WR9X521 Control, Temp - AppliancePartsPros.com
I can find the defrost timer, but not sure about the thermostat.
Thanks again,
yuan
  #6 (permalink)
Old 03-31-2014, 11:09 AM
Senior Expert
APP Volunteer
Default
Below are the parts for that unit
Parts for GE TFX25PRYFWW Refrigerator - AppliancePartsPros.com
The thermostat is item 424 in section 04.
Unfortunately it is no longer available.
Give the parts people a call to see if they have a substitute.
__________________
  #7 (permalink)
Old 03-31-2014, 12:10 PM
Junior Member
Default
Denman,
Thank you very much for your help!
yuan
  #8 (permalink)
Old 04-09-2014, 04:43 PM
Junior Member
Default
I bought one from ******** and replaced the thermostat. The refrigerator is running, but the temperature is too low at 30F even when I move the adjustment to 1 on the scale 1-9.
Is it possible that the thermostat is defective? How do I test it?
Thanks,
Yuan
  #9 (permalink)
Old 04-10-2014, 02:07 AM
Senior Expert
APP Volunteer
Default
Is the unit cycling or is it on all the time?
If on all the time then it could be defective.
You could hold the end of the capillary tube on an ice cube to see if the thermostat's contacts open.
It is important that the capillary end be in the same place as the original.
You could try moving it closer to the freezer compartment to see if it will get more of the freezer temperature and therefore shut off sooner.
__________________
  #10 (permalink)
Old 04-10-2014, 05:11 AM
Junior Member
Default
The unit is cycling.
Is the coil thing called capillary? It is confined in a frame in my model. I will try moving it to see the result.
Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag refriderator not working George48051 Refrigerator & Freezer Repair 6 05-15-2013 05:54 PM
Whirlpool refriderator jtansy Oven Repair (including Ranges and Cooktops) 0 07-31-2011 02:40 PM
Kenmore Refriderator zippie Refrigerator & Freezer Repair 0 05-31-2011 10:13 AM
Refriderator Pooky Refrigerator & Freezer Repair 0 08-13-2010 04:55 AM
GE refriderator jeff5252 Refrigerator & Freezer Repair 1 07-13-2009 04:39 PM
