I replaced the mother board with GEH part number WR55X10942 from AppliancePartsPros.com when my compressor quit running . Now the compressor runs fine and the temperatures are good. However since replacing the Mother Board the evaporator fan pulses. The voltage at the J2 connector pins 3 to 4 is constantly changing from 4.5-5.4 volts on average. Is this caused by a bad Mother board or a bad fan motor? The motor has never been replaced. Thanks for your help. Don
