Have an Amana side-by-side fridge with the water/ice dispenser on the outside of the freezer door. No problems with the ice cubes or dispenser. The water dispenser releases water with good flow when activated. After getting water it drips for a while, enough to fill the tray and make a puddle on our wood floors.
From reading other threads sounds like the water valve on the back, but not sure if this is the primary or secondary valve. Or do I need to do both?
