Hi, i have issues with my water dispenser not giving a good flow. My ice maker want make full size ice cubes.
I recently installed a new water filter.
I installed a new water valve.
I also installed a new condensing fan motor. while in this area behind the access panel, i cleaned the condenser coils.
12 hrs later, the water pressure increased a little but the size of the ice hasnt changed. the ice is also white/cloudy looking.
please help if you can.:)
