Forum Rank:: Member
I have replaced the water valve because it was showing too many ohms across the solenoid. Checked the voltage at the ice maker and it showed 118 VAC. Replaced ice maker assembly. Even went so far as to use a blow dryer on the inlet line to make sure no ice was in the line. What would be my next step?
