seminar1
#1 Posted : Saturday, March 1, 2014 9:33:44 AM(UTC)
seminar1
The fill tube is frozen. Removed the ice maker and half the tube, but the other half in the freezer is frozen too. There are no screws on the back of the unit to remove the other half of the tube. It is a molded plastic square with the water supply line clamp and that's it. The city shut the water off for 1/2 day, and coincidently the tube froze for the first time ever that day. Before I call it a leaking valve, I'd like to clear the tubes and run the unit. Any idea on how to get the second half out?
Thanks, in advance,
Steve
seminar1
#2 Posted : Sunday, March 2, 2014 9:04:37 AM(UTC)
seminar1
Follow up: I ended up not trying to remove the molded plastic second half of the tube, but instead carefully drilled out the ice that was frozen in it. Also cleared the inlet line of air, put the unit back together and crossed my fingers. This morning a full dispenser of ice.......lucky me! Good luck all.... Steve
