GE Profile performance model number tfx30pdbbb Freezer door seal. Minde you i used to do appalance repair in the 80s but i cant for the life of me get this tricky @%% thing apart ... the gasket doesnt pull open to reveal the secret 1/4 screws that loosen the seal ...
I have tugged on the top corner and is seems like there is dbl sided tape holding it to the door ... Under the out side corner where i have delamanited the tape i can see the philips screws that hold the metal strips on,but there is now way they clamp the gasket ....
is the gasket self suported and simply goes on with dbl sided tape ... thats going to suck.I need to take door apart to repair the dispencer tube
thank
Bob
