Discuss
pop machine
 in
Refrigerator & Freezer Repair
Turned on machine and it brings the temp down to 36 degrees in about ten minutes. The compressor draws 6.4
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » pop machine
  #1 (permalink)
Old 02-23-2014, 12:21 PM
Junior Member
mitchlewis is on a distinguished road
Default pop machine
Model Number: vendco   Brand: -other-   Age: More than 10 years
Turned on machine and it brings the temp down to 36 degrees in about ten minutes. The compressor draws 6.4 amps. Then the compressor shuts off, and when it tries to turn back on it draws 27 amps and tries for 1 second then I hear a click and it shuts down for about 25 seconds then it tries to start again and repeats this cycle as the temp inside the unit rises to room temp. I checked the ohms of the compressor and got 1.2,15.6 and 16.7. I checked the over temp button and have conductivity when cold and the relay passes the conductivity tests. Is the compressor toast? Any other tests? Thanks for your help, Mitch
Related Models
Hoover VER1360AGH RANGE- F/S STD ELE
Gaggenau VF112-610
Gaggenau VF230-610
Gaggenau VF332-610
Frigidaire VG21AW3 Tap(v1) / Gas Range
Frigidaire VG21AW3-23 Tap(v2) / Gas Range
Gaggenau VG223-812
Gaggenau VG230-811
Gaggenau VG231-211CA
Gaggenau VG232-212CA
Amana VG3019 WASHER-TOP LOADING
Frigidaire VG30AW3 Tap(v1) / Gas Range
Frigidaire VG30AW3-23 Tap(v2) / Gas Range
Frigidaire VG30BW2 Tap(v1) / Gas Range
Frigidaire VG30BW2-23 Tap(v2) / Gas Range
Frigidaire VG30CW2 Tap(v1) / Gas Range
Frigidaire VG30CW2-23 Tap(v2) / Gas Range
Gaggenau VG330-811
Gaggenau VG352-812
Gaggenau VG353-112
Gaggenau VG353-212
Frigidaire VG36DW2 Tap(v1) / Gas Range
Frigidaire VG36DW2-23 Tap(v2) / Gas Range
Amana VG5019 WASHER-TOP LOADING
Amana VHC-2 RANGE- S/C S/I DDRAFT GAS
General Electric VISR208DT8WW Washer
General Electric VISR208DTAWW Washer
General Electric VISR309JT5AA Washer
General Electric VISR309JT6AA Washer
General Electric VISR309JT8AA Washer
General Electric VISR309JTAAA Washer
General Electric VJSR2070T2AB Washer
General Electric VJSR2070T2WB Washer
General Electric VJSR2070T3AB Washer
General Electric VJSR2070T3WB Washer
General Electric VJSR2070T5AB Washer
General Electric VJSR2070T5WB Washer
General Electric VJSR2070T6AB Washer
General Electric VJSR2070T6WB Washer
General Electric VJSR2070T8AB Washer
General Electric VJSR2070T8WB Washer
General Electric VJSR2070TAAB Washer
General Electric VJSR2070TAWB Washer
Gaggenau VK111-610
Gaggenau VK230-610
General Electric VKSR2100T2WW Washer
General Electric VKSR2100T3WW Washer
General Electric VKSR2100T5WW Washer
General Electric VKSR2100T6WW Washer
General Electric VKSR2100T8WW Washer
General Electric VKSR2100TAWW Washer
General Electric VKXR4100T2WW Washer
General Electric VKXR4100T3WW Washer
General Electric VKXR4100T5WW Washer
General Electric VKXR4100T6WW Washer
General Electric VKXR4100T8WW Washer
General Electric VKXR4100TAWW Washer
Gaggenau VL021-707
Gaggenau VL022-707
Gaggenau VL023-707
Gaggenau VL030-707
Gaggenau VL031-707
Gaggenau VL040-707
Gaggenau VL041-707
Gaggenau VL051-707
Gaggenau VL330-707
Gaggenau VL331-707 211100 UP
Gaggenau VL331-707upto 211099
General Electric VLD4209L15BB Dishwasher
General Electric VLD4209L15SS Dishwasher
General Electric VLD4209L15WW Dishwasher
General Electric VLD4209L20BB DISHWASHER
General Electric VLD4209L20SS DISHWASHER
General Electric VLD4209L20WW DISHWASHER
General Electric VLLR1020T0WO Washer
General Electric VLLR1020T1WO Washer
General Electric VLSR1090G0WW Washer
General Electric VLSR1090G2WW Washer
General Electric VLXR1020A0WO Washer
General Electric VLXR1020A1WO Washer
General Electric VLXR1020A2WO Washer
General Electric VLXR1020A3WO Washer
General Electric VLXR1020A4WO Washer
General Electric VLXR1020A4WW Washer
General Electric VLXR1020A5WO Washer
General Electric VLXR1020D0WO Washer
General Electric VLXR1020D2WO Washer
General Electric VLXR1020D5WO Washer
General Electric VLXR1020T2WB Washer
General Electric VLXR1020T3WB Washer
General Electric VLXR1020T4WB Washer
General Electric VLXR1020T5WB Washer
General Electric VLXR1020T8WB Washer
General Electric VLXR1020TAWB Washer
Thermador VM-275
Thermador VM-300
Thermador VM-350
Thermador VM-400
Thermador VM-410 HOOD VENTILATOR
Thermador VM-450
Magic Chef VM11A-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11B-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11B-8PDY MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11BN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11C-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11CN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11D-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11D-8P-DY MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11DN-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11EB-8P MWAVE- MOUNTED UNDER CABINET
Magic Chef VM11EV-8P MWAVE- MOUNTED UNDER CABINET
Maytag VM12AB MWAVE- MOUNTED UNDER CABINET
Maytag VM12AM MWAVE- MOUNTED UNDER CABINET
Maytag VM12AV MWAVE- MOUNTED UNDER CABINET
Maytag VM12AV-1 MWAVE- MOUNTED UNDER CABINET
Thermador VM410
Magic Chef VM9B-8 MWAVE- MOUNTED UNDER CABINET
Frigidaire VP21AW3 Tap(v1) / Gas Range
Frigidaire VP21AW3-23 Tap(v2) / Gas Range
Frigidaire VP21AW4 Tap(v3) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
machine won't do anything matt24 Washer Repair 0 02-03-2014 08:11 PM
New ice machine tripog Refrigerator & Freezer Repair 4 02-07-2012 07:21 PM
Ice machine barbetti Refrigerator & Freezer Repair 0 02-05-2010 06:32 AM
Machine won't run snowgirluk Dishwasher Repair 1 02-19-2009 03:19 PM
Machine does nothing Rauner1 Washer Repair 6 09-23-2008 01:19 PM
