Discuss
Broken Water Actuator
 in
Refrigerator & Freezer Repair
I have a Kenmore side-by-side refrigerator with a broken water actuator lever. I ordered and received the replacement (
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Broken Water Actuator
  #1 (permalink)
Old 02-13-2008, 05:58 PM
reneesue57 reneesue57 is offline
Junior Member
reneesue57 is on a distinguished road
Default Broken Water Actuator
Model Number: 25351694103   Brand: Kenmore   Age: 1 - 5 years
I have a Kenmore side-by-side refrigerator with a broken water actuator lever. I ordered and received the replacement (part #24 from schematic) but can't seem to get the panel off to access the part. Anyone else had this problem? Go in from front?? or back??
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-14-2008, 04:18 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The dispenser has to be taken apart from the front.
The frame is holding by the three screws (#82 on the break down diagram) on the bottom.
Do not forget to unplug the fridge first.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 02-14-2008, 07:33 PM
Junior Member
Default
Thanks Gene...got the disassembly figured out...put the actuator in, now when I plug the front panel back in the ice dispenser runs continuously!! Any easy suggestions? or should I through the towel (or the ice bucket!!) in and call a repairman?
  #4 (permalink)
Old 02-14-2008, 09:34 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Looks like the switch inside is stuck. Possible you misalign the actuator.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
broken glass terririch25 Oven Repair (including Ranges and Cooktops) 1 01-16-2008 01:51 PM
water actuator on water dispenser sixkings Refrigerator & Freezer Repair 1 01-07-2008 10:33 AM
Actuator replacement Green14825 Refrigerator & Freezer Repair 1 11-25-2007 08:00 AM
Broken Timer? drew1107 Washer Repair 1 11-14-2007 08:47 PM
replacing the Actuator on my Frigdaire christopher0077 Refrigerator & Freezer Repair 0 08-10-2007 02:27 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
