Discuss
location of defrost timer
 in
Refrigerator & Freezer Repair
I believe that my Kenmore chest freezer is stuck in defrost mode. The food on top is cold but not
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » location of defrost timer
  #1 (permalink)
Old 02-20-2014, 06:08 AM
Junior Member
simons98 is on a distinguished road
Default location of defrost timer
Model Number: 253.9163111   Brand: Kenmore   Age: More than 10 years
I believe that my Kenmore chest freezer is stuck in defrost mode. The food on top is cold but not frozen. It has done this for the last few years, however, it usually "fixes" itself. My question is, I looked in the panel where the compressor is but did not find anything that looked like a defrost timer. Does this model have a defrost timer? Thank you!
Related Models
Frigidaire 2530A GAS RANGE
Frigidaire 2530B GAS RANGE
Frigidaire 2530C GAS RANGE
Frigidaire 2530D GAS RANGE
Frigidaire 2530E GAS RANGE
Kenmore 25310301000 CHEST FREEZER
Kenmore 25310301001 CHEST FREEZER
Kenmore 25310311000 CHEST FREEZER
Kenmore 25310311001 CHEST FREEZER
Kenmore 25310311002 FREEZER
Kenmore 25310911990 FREEZER
Kenmore 25310911991 CHEST FREEZER
Kenmore 25310911992 CHEST FREEZER
Kenmore 25311301100 FREEZER
Kenmore 25311301101 FREEZER
Kenmore 25311311100 CHEST FREEZER
Kenmore 25311312100 FREEZER
Kenmore 25311312101 FREEZER
Kenmore 25311312102 SEARS/FREEZER
Kenmore 25311321100 CHEST FREEZER
Kenmore 25311321101 FREEZER
Kenmore 25311351100 FREEZER
Kenmore 25311351101 CHEST FREEZER
Kenmore 25311351102 FREEZER
Kenmore 25311511100 CHEST FREEZER
Kenmore 25311511101 FREEZER
Kenmore 25311521100 FREEZER
Kenmore 25311521102 CHEST FREEZER
Kenmore 25311521103 FREEZER
Kenmore 25311531100 FREEZER
Kenmore 25311531101 FREEZER
Kenmore 25311531102 FREEZER
Kenmore 25311531103 FREEZER
Kenmore 25311541100 CHEST FREEZER
Kenmore 25311541102 FREEZER
Kenmore 25311711100 FREEZER
Kenmore 25311711101 CHEST FREEZER
Kenmore 25311711102 FREEZER
Kenmore 25311821100 FREEZER
Kenmore 25311821101 FREEZER
Kenmore 25311911100 FREEZER
Kenmore 25311911101 FREEZER
Kenmore 25312021100 FREEZER
Kenmore 25312021101 FREEZER
Kenmore 25312021102 FREEZER
Kenmore 25312541100 FREEZER
Kenmore 25312541102 SEARS/FREEZER
Kenmore 25312551100 FREEZER
Kenmore 25313009100 FREEZER
Kenmore 25313051100 FREEZER
Kenmore 25313051101 FREEZER
Kenmore 25313051102 FREEZER
Kenmore 25313051103 FREEZER
Kenmore 25313312101 FREEZER
Kenmore 25313351100 FREEZER
Kenmore 25313500100 FREEZER
Kenmore 25313500101 FREEZER
Kenmore 25313500102 FREEZER
Kenmore 25313500103 FREEZER
Kenmore 25313511100 CHEST FREEZER
Kenmore 25313511101 FREEZER
Kenmore 25313511102 FREEZER
Kenmore 25313541101 FREEZER
Kenmore 25313541102 FREEZER
Kenmore 25313551100 FREEZER
Kenmore 25313551101 FREEZER
Kenmore 25313711100 FREEZER
Kenmore 25313711101 FREEZER
Kenmore 25313711102 FREEZER
Kenmore 25313712100 FREEZER
Kenmore 25313712101 FREEZER
Kenmore 25313911100 FREEZER
Kenmore 25313911101 FREEZER
Kenmore 25313911102 FREEZER
Kenmore 25314092101 FREEZER
Kenmore 25314092102 FREEZER
Kenmore 25314092103 FREEZER
Kenmore 25314342100 FREEZER
Kenmore 25314342101 FREEZER
Kenmore 25314342102 FREEZER
Kenmore 25314352100 FREEZER
Kenmore 25314352101 FREEZER
Kenmore 25314352102 FREEZER
Kenmore 25314502100 FREEZER
Kenmore 25314502101 FREEZER
Kenmore 25314502102 FREEZER
Kenmore 25314502103 FREEZER
Kenmore 25314502104 FREEZER
Kenmore 25314502105 FREEZER
Kenmore 25314512100 FREEZER
Kenmore 25314512101 FREEZER
Kenmore 25314512102 FREEZER
Kenmore 25314512103 FREEZER
Kenmore 25314512104 FREEZER
Kenmore 25314542100 FREEZER
Kenmore 25314542101 FREEZER
Kenmore 25314542102 FREEZER
Kenmore 25314542103 FREEZER
Kenmore 25314542104 FREEZER
Kenmore 25314542105 FREEZER
Kenmore 25314552100 FREEZER
Kenmore 25314552101 FREEZER
Kenmore 25314552102 FREEZER
Kenmore 25314582100 FREEZER
Kenmore 25314592100 FREEZER
Kenmore 25314592101 FREEZER
Kenmore 25314592102 FREEZER
Kenmore 25314702100 FREEZER
Kenmore 25314702101 FREEZER
Kenmore 25314702102 FREEZER
Kenmore 25314702103 FREEZER
Kenmore 25314702104 FREEZER
Kenmore 25314712100 FREEZER
Kenmore 25314712101 FREEZER
Kenmore 25314712102 FREEZER
Kenmore 25314712103 FREEZER
Kenmore 25314772100 FREEZER
Kenmore 25314772101 FREEZER
Kenmore 25314772102 FREEZER
Kenmore 25314772103 FREEZER
  #2 (permalink)
Old 02-20-2014, 12:25 PM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Chest freezers do not have auto defrost so there is no timer.
__________________
  #3 (permalink)
Old 02-23-2014, 06:12 AM
Junior Member
Default
Quote:
Thank you for the reply. So, based on the symptoms, do you have and suggestions as to why the freezer intermittently does this?
  #4 (permalink)
Old 02-23-2014, 08:55 AM
Senior Expert
APP Volunteer
Default
The most likely cause is a leaking door seal.
Take a piece of two inch wide paper and place it between the seal the the units frame.
Then pull it out to check the seal.
Work your way all around the door every 6 inches or so.
When it does this does the compressor run all the time or is there any other symptom that seems strange
I would put a thermometer in it and check the temperatures.
Perhaps turn it a little colder.
Could be that the thermostat is sticking open once in a while.
This could be checked by turning it slightly colder when this happens.
If the compressor kicks on, I would replace the thermostat.
__________________
  #5 (permalink)
Old 02-24-2014, 06:58 PM
Junior Member
ssauer40 is on a distinguished road
Default
Condenser coils dirty/dusty? These are the coils outside that convert the refrigerant from a hot gas to a hot liquid. If its dusty, it doesnt remove the heat and cooling becomes poor. Real easy to gather dust around the coils. They may be in the back, or bottom of both. .
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Location of Defrost Timer meppwc Refrigerator & Freezer Repair 2 01-23-2014 02:16 AM
Defrost timer location? mbdickerson Refrigerator & Freezer Repair 0 08-02-2010 06:53 PM
Defrost timer location WayneW Refrigerator & Freezer Repair 1 07-12-2010 04:46 PM
Defrost timer location ? ctjch11 Refrigerator & Freezer Repair 9 05-06-2010 03:43 AM
location of defrost timer Frank Cool Fuel Refrigerator & Freezer Repair 3 06-26-2009 10:42 AM
