Icemaker stopped working, I added water thru cup and then it actually worked for about 3 days and then stopped. It is getting power and actually I hooked a wire between L and V and heard the water intake valve. I removed the icemaker, but still plugged in and again tested the water intake valve but no valve sound this time. I then unplugged icemaker and run the resistance test but got no readings whatsoever. I am now thoroughly stumped. Any suggestions
